Hi Roger, Thought you might like to see the escalated reply from Sony. Doesn't look like they will admit that the player is at fault rather it's the media server or the user or the PC or whatever, not their player of course. I've sent another reply with a few questions, mainly....is there a firmware update in the pipeline. As they don't think there is anything wrong with their player...I'm not too hopeful of an update anytime soon. Cheeky suggesting I spend ages trawling a load of other forums in the hope that might be able to help everyone here on WHF when surely they sure be able to help us all out easily.
Assuming this is moderated, perhaps someone from the magazine could address this issue directly to Sony, when they next pop in to the office.
Thank you for your enquiry.
in relation to your email, the TV will not natively see the files you have on your computer, the 2 servers you have advised, Media Player 11 and Twonky from my knowledge do not broadcast the original format, they will have to transcode the files, normally in an MPEG format, i can only recommend you check the extensive Twonky forums for tweaking the program for use with Sony products, this unfortunately we do not support the packages.
This is also related to video stutter, the file in being broadcast this way and has nothing to do with the receiver, the player and the TV use packets of data as they are received are shown almost instantly, the TV or the player are not responsible for the quality or smoothness of the image, again you would need to play with the server settings to get this right, there are lots of restrictions in both of the advised servers, firstly Windows Media Player 11 will only broadcast files it supports and all are sent in MPEG2_PS_ Standard Def, depending which version of Twonky is being used, again numerous restrictions and broadcast options are available.
As this issue is not down to the Sony products I cannot guarantee your retailer would offer a refund, however if you could send me a sample of video you are having issues with I can test on a server I have here, although not one you are using i can check that the files are ok.
I hope this information is of assistance, and i hope your search of the forums will help you find the answers so you can advise the other reporting issues on your forum.
