BenLaw said:We did this recently.
There was not a consensus.
altruistic.lemon said:I'd have thought if the specs are the same, the sound is pretty much going to be the same too.
drummerman said:BenLaw said:We did this recently.
Never is Ben. Its just my take on it ... sorry for some reason I can't post a new thread in one go! |(
Very nice systems you have by the way. I had a look through some of the reader photos recently.
Hoopsontoast, I am not sure if you are the same guy as over at DIY Audio? If you are then you know a lot about amplifier design and perhaps agree with me. I would be interested to hear your take on the thesis but in essence, I agree with you that not all amps sound the same, if perhaps not for the same reasons other people assume.
regards
hoopsontoast said:drummerman said:BenLaw said:We did this recently.
regards
Hi am on diyaudio but not as hoopsontoast. I dont know much about technical amplifier design.
Two similar design amplifiers 'should' sound the same, but they dont. A 1.5w SET WILL sound different to a 200w SS amp given its output characteristics. Two 1.5w SET amps based on the same tube (SV83/EL84 for example) might sound different with different tubes, which can be put down to manufacturing tolerances and differences in the tubes themselves.
You have to take into account the speaker its being used with. For example a monster 200w SS amp is not likely a good match for some 99dB full range horn speakers, where as the 1.5W SET amp is likely to be a better match, with its high output impedance rolling off the elevated treble in the full range driver.
This is obviously a wide mis-match example, very similar amps into normal speakers I would guess there would be less difference as long as the amplifier is not being driven into clipping or distortion.
But then I have heard (IMO) a difference going between very similar amplifiers (design and spec) into easy to drive speakers so really at the end of the day, its subjective.
If someone hears a difference (positive) in a change in amplifier, cable, cd transport or even cable lifters and other foo, and is happy to pay the price for an improvement to them, then fair play.
IME these sorts of 'tweaks' make little difference so I will leave it at amplifier make a big difference, but In My Experience, less so on other 'upgrades'.
BenLaw said:drummerman said:BenLaw said:We did this recently.
Thanks dm
CnoEvil said:Do all blonde ladies look the same? :twisted:
A quick listen to Arcam vs Cyrus will show a difference, or Luxman (AB) vs Bryston
Even Tube amps can sound different - Unison Research vs VTL, as an example.
MajorFubar said:Anyone who thinks all amps sound the same is very welcome to come and listen to my HiFi. I still have a Cyrus II+PSX here, and a Marantz PM66KI. Their different tonal characteristics are so obvious you won't need to ABX.
drummerman said:Well, I'm not 'all' blondes, thank you ...
drummerman said:Must mention your system as well as Ben's. Admirable and beyond what most of us can aspire to. Very nice indeed.
drummerman said:As to Arcam versus Cyrus, or other similar combinations, if that is your experience then I of course respect that.
drummerman said:Perhaps it would be worth mentioning though that if one of them had tone or a loudness control, the outcome would imo be more indifferent than many people would expect. I respectfully refer you to my OP for more on that. Of course thats just my take on it.
drummerman said:Nice though, that there is such a broad base of opinions. It makes everything more interesting
plastic penguin said:This is my interpretation, but amplifiers are speaker sensitive, hence why Cyrus generally sound better with smoother monitors, while Nad excel with brighter (livelier) speakers.
Amplifiers - within a £200 price scale - have slight tonal differences. However, when comparing budget with higher end amps then there is a (very) noticeable uplift.
Last week I hooked up my old Arcam Alpha and it sounded almost primitive compared to the Leema.
Another example was when I had a Cyrus 8VS2 (£800) and Roksan Kandy LIII (£650) in my living room at the same time - the kandy won hands down hooked to my MAs. Tecnically the Cyrus was a better unit, but did sound disjointed compared to the Kandy.
Also room acoustics has a fairly significant say in how the overall system sounds.
So to answer the question: No.
plastic penguin said:...
Yes, I agree, take the power issue out of the equation, in and around the same price bracket, there's minimal difference.
