I was brought up to believe heat was the enemy of electrical components.My Rega Elicit mk5 has replaced a radiator in the house.
Have to listen while it warms up. After 4-5 hours it starts to get me worried about spontaneous combustion 😬
Not if you had a valve amp or a solid state one with decent casework.I was brought up to believe heat was the enemy of electrical components.
Interesting, my class D Gato Audio 250S-NPM seems to get a little better after maybe 20-30 mins of use. This could be subjective however, I was going to ask if class D is different in this respect to class A and others ... anyone know?If I was demonstrating Hifi for a living I’d definitely put it on 20-30 minutes before listening if I could.
My power amp is solid-state Class A and the manual says it takes up to an hour to fully warm up, and sounds better as a result. My class D integrated amp is silent on this, but I think it’s better after about twenty minutes. YMMV!
Agree about those amplifiers, not sure about cables as all but one of mine are second-hand so assume they have already been burnt -in.... 🙂I could see my breath in the room this afternoon - system sounded great (never better) from the first seconds.
I believe in the need for solid state electronics to warm up about as much as I believe they need to be 'burned in'.
The quote below is taken from the manual of my H95, this would suggest that even the guys who make the stuff believe that allowing their kit a short warm up period can help your listening experience.I could see my breath in the room this afternoon - system sounded great (never better) from the first seconds.
Noted. If they can honestly hear a difference after 15 minutes then they have better hearing than me, but that's nothing new... 🙂The quote below is taken from the manual of my H95, this would suggest that even the guys who make the stuff believe that allowing their kit a short warm up period can help your listening experience.
That being said, our products sound even better when they are warmed up, typically after about 15 minutes of listening at a moderate volume.
I’m not sure one can generalise by Class. My Primare integrated barely gets warm to the touch, and has a closed case - no slots like most amps. By contrast my Nord NC500 with Hypex Class D modules ran quite warm for its type, as the chassis was in effect a heat sink. But the Nord definitely sounded a bit ‘mechanical’ when first switched on, and ‘relaxed’ and sounded more comfortable within half an hour.Interesting, my class D Gato Audio 250S-NPM seems to get a little better after maybe 20-30 mins of use. This could be subjective however, I was going to ask if class D is different in this respect to class A and others ... anyone know?
Yea, tough guys like you obviously don’t pick up these nuances! 😉🤣I could see my breath in the room this afternoon - system sounded great (never better) from the first seconds.
Yes, like I previously said, Marantz specify 4 minutes settling time after switch on, before adjusting idling current.The quote below is taken from the manual of my H95, this would suggest that even the guys who make the stuff believe that allowing their kit a short warm up period can help your listening experience.
I have always been aware from the late 1980's when I had my first proper HiFi system that you should allow your system time to warm up, where did this come from I honestly cannot remember but as I was an avid reader of the Hifi press back then I probably picked it up from there and have carried that forward to today.Yes, like I previously said, Marantz specify 4 minutes settling time after switch on, before adjusting idling current.
We must assume that at least one Hegel engineer could blindly, reliably tell whether an amp has been on for 1 or 16 minutes 🤔🙂
Ask yourself, could you?
That probably helps a lot of people to hear a difference .music fidelity lights change colour when it's up to optimal temperature
I somehow miss the audible differences that many others hear between cables too - not sure what's wrong with me.I may or may not have experienced this with my amps too... if I did I just learnt to ignore it 🙂
I should hope so....System sounded great (never better)...
Powerful processors need heatsinks in order not to literally burn to death. Apart from that, there is a threshold temperature for each individual component. Which I would only worry about when a fan gets broken or when you build your own gear. Manufacturers have sorted all out and heat at the outside is a sign it is released.I was brought up to believe heat was the enemy of electrical components.
