CnoEvil said:BenLaw said:Ah good, at least you accept that when someone says 'there's definitely a difference because I heard it' we can't take that at face value and it is 'more complicated than it first appears to be'.
Likewise, when someone who hasn't heard it, says there isn't a difference. 😛
BenLaw said:Yeah. Fwiw that's not me. My initial inclination would be they do, but I've never done back to back amp comparisons with my speakers, source and room. Reading some of the science that I linked to earlier (I'm sure no-one read it but it's useful to understand what's going on IMO before choosing kit one likes the sound of) is quite persuasive that the harbeth challenge must be right for properly designed amps driving speakers they can handle, at the same volume, before clipping. You'll note that this does not apply to tube amps and certain class A, which add detectable second order harmonics, which give the 'warmth' ('musicality') you like in your amplification.
BenLaw said:Native_bon, I know you say none of your work has been officially released but do you have links to anything you've produced? I'd be really interested to hear some 🙂
Native_bon said:BenLaw said:Native_bon, I know you say none of your work has been officially released but do you have links to anything you've produced? I'd be really interested to hear some 🙂
Off topic. Also. house rules.
CnoEvil said:BenLaw said:Yeah. Fwiw that's not me. My initial inclination would be they do, but I've never done back to back amp comparisons with my speakers, source and room. Reading some of the science that I linked to earlier (I'm sure no-one read it but it's useful to understand what's going on IMO before choosing kit one likes the sound of) is quite persuasive that the harbeth challenge must be right for properly designed amps driving speakers they can handle, at the same volume, before clipping. You'll note that this does not apply to tube amps and certain class A, which add detectable second order harmonics, which give the 'warmth' ('musicality') you like in your amplification.
A true SS Class A amp removes crossover distortion and doesn't have the "weakness" of valves.....though, before one dismisses valves, they are worth hearing.
VTL amps produce some of the most dynamic, natural sounds I have ever heard. Not all Valve amps are created equal.
BenLaw said:I wasn't talking about crossover distortion, nor dismiss valves. Read the article.
BenLaw said:Native_bon said:BenLaw said:Native_bon, I know you say none of your work has been officially released but do you have links to anything you've produced? I'd be really interested to hear some 🙂
Being off topic has never stopped me before! And unless there is obscenity there are no house rules problems. Please?
CnoEvil said:BenLaw said:I wasn't talking about crossover distortion, nor dismiss valves. Read the article.
I missed it because it wasn't in blue. :doh:
Interesting.
BenLaw said:CnoEvil said:BenLaw said:I wasn't talking about crossover distortion, nor dismiss valves. Read the article.
Interesting.
Yeah, that seems to happen most (tho not all) times I post with my phone, annoying.
MajorFubar said:No offence but that's the same (wrong) line of thinking which believes that the SQ of an amp is directly related to how loud it goes. I'm sure you would be very easily able to disprove that theory to yourself by going to listen to a number different amps, blind or not, and you don't have to spend megabucks to hear it. Listen to something from Arcam and Cyrus for example and it's blindingly obvious, their presentation is completely different to each other.Illinoisian said:Yes. I think if it can drive the rated ohms of your speakers, and if distortion is below .1%, every amp sounds the same. This endless and expensive search for costly high-end amps is all manufacturers' hype (IMHO).
CnoEvil said:char_lotte said:All beans sound the same.
No they don't! :twisted:
fr0g said:CnoEvil said:fr0g said:No, it shows that your brain fills in when it expects something to taste (or sound) a certain way.
This may be partially true, but it's too simplistic (imo). Colour and taste are inextricably bound together.....probably going back to our ancestors, where being hardwired to avoid eating things of certain colours could save your life.
Using the right food colouring to make stuff look more appetizing, is very much based on known science.
And I'm pretty certain the purveyours of aircraft-grade steel-cased amps at aircraft-grade prices know something about the equivalent, inextricably linked science when it comes to sound 🙂
By the way, I do think amps sound different. I'm certain of it. But I do wonder about dm's interesting concept of them sounding the same with tone controls...on that I think it's a very big maybe.
drummerman said:fr0g said:CnoEvil said:fr0g said:No, it shows that your brain fills in when it expects something to taste (or sound) a certain way.
FrOg, certainly a maybe yes. I have a Denon receiver in my bedroom system. Not much power. Has tone controls. Use the loudness facility and it sounds like a completely different amplifier. Powerful and fuller mids, I am pretty certain I could make it to be perceived as a Naim (example) with a little tweaking as long as its within the envelope of what it can do. All an illusion and at higher levels it will run out of puff. The problem will arise when I try to do the same with amplifiers that have high inherent distortion such as certain valve amplifiers or transistor ones with predominately thirds ... that hard, glassy sound. It would be difficult to replicate these. Similar with amplifiers that have (very) low damping factors. Speakers with high bass damping would have to be used in a blind test to even the field.
I think thats where the confusion and difference of opinions come from. There are a fair few factors determining how an amplifier speaker combination will sound but basically, I do believe that most well engineered amplifiers are comparable in sound as long as certain common factors are adhered to, as mentioned before and as long as they are used within their design parameters. A few watts in many cases, which is all most people use in every day listening.
I have noticed that there are a fair few of you from the 'dark side' on here at the moment ... must come over and give my Xmas wishes. Sent one to the little man but I think he still has the hump.
Have a great Xmas and a good New Year
regards
BigColz said:I think I cut and pasted some bits wrong at the start so you may have a ******** deja vu monent when reading it.. :doh:
drummerman said:BigColz said:I think I cut and pasted some bits wrong at the start so you may have a ******** deja vu monent when reading it.. :doh:
Understand BigColz, not a problem.
Note, I said well engineered. Now, there are plenty of examples of so called 'high end' products which suffer from all sorts of ailments because of bad design. Just to give one example, there are many more, Micromegas last amplifier with unshielded streaming module. Interference all over the place and it was apparently easily audible.
Well engineered doesn't necesseraly has to be expensive. Using boutique parts does not guarantee good measurements or sound. Proper design, circuit layout etc does go a long way towards it. There are many expensive amplifiers that have high noise floors, hum, high output impedance etc etc.
regards
jcbrum said:Valve amps sound like has-beans.
MajorFubar said:Blimey is this thread still banging on, when the indisputable literal answer to the question is quite simply 'no'...
