TrevorS
I was in the hi fi business for many years. I used to have a Linn LP12 / Naim tri-amp / Linn Isobarik setup. Over the years I’ve witnessed the debate between transistors and valves, CD’s and vinyl, hi fi perfection at any cost, but one thing that has never been mentioned or discussed in pre-amplifier or integrated amplifier reviews is the adherence to the RIAA curve at the phono input stage. For those who are mystified, since the inception of the LP as a sound carrying format, all discs have been mastered and stamped with pre-emphasis applied to try and alleviate certain inherent problems with the discs themselves. De-emphasis is then applied at the phono input stage to counteract the effect. However, I have never seen any review where the accuracy of the de-emphasis curve is tested. This could account for many sonic differences between pre-amplifiers.
Audio Science Review measure this:
Reactions: nopiano
Maybe you can find the article mentioned below but 1979 is before internet.....
Stanley Lipshitz put a cat among the pigeons in the June 1979 issue of the Journal of the Audio Engineering Society with an unprecedentedly detailed examination of the circuits used to apply RIAA/IEC deemphasis. He concluded that many of these were in error as a result of incorrect design equations being applied, or because the effects of other time constants in the circuit, and/or the influence of amplifier loop gain, were ignored. The corollary was another round in the nascent objectivist/subjectivist struggle in which it was claimed that many of the disparities heard between different amplifiers were due to nothing more exotic than significant departures from flat frequency response.
https://www.stereophile.com/content/cut-and-thrust-riaa-lp-equalization-page-2
Welcome to the forum, Trevor!
Hifi News and Stereophile test phono stages too. You must have become out of touch with audio not to have seen either of them!
I recall years ago that tests actually showed the RIAA curve, but with very few of us understanding what it should look like it’s more sensible to show the outcome. Hence a smooth line, with probably a roll off below 20Hz is desirable.
In fact there was just such a graph in Stereophile’s review of the new Quad 33/303 that I was reading last night. However, mine was a paid subscription copy, but it’s already on their website for free. See Fig 9…
PS. For everyone else, the Reviewer Reviewed box out of the same article is a great reminder of how reviewing has evolved.
As @nopiano says above, stereophile frequently has RIAA curve analysis in its reviews. If what you mean by 'never seeing' this info is you 'never see in WHF' then I'm afraid WHF is not a great place to look for vinyl playback. Use a reference cart in comparing turntables? Use a reference TT in comparing carts? All far too much like hard work for WHF .
