- Aug 10, 2019
- 2,556
- 5
- 0
Hi All,
I was browsing the Russ andrews web and this inline attenuator claim to solve brightness .
does anyone have install the inline attenuator with good results?
Is that so that brighness is caused by the "wrong attenuation level" as explained by Russ andrews as below? so by adding attenuator plugs there is better result?
"Ever noticed that the sound from CD sounds 'bright' or harsh? The problem is very common and is caused by the relatively high outputs from a CD player 'overloading' the amplifier's input. And amazingly, the problem even occurs from equipment from the same manufacturer. If the CD player's output is correctly matched to the amplifier's input, for average listening your amp's volume control should be in the centre of its range. This allows you to play your music very quietly when needed (for late night listening) but also very loud if needed. "
Best Rgds,
Alvin
Best Rgds,
Alvin
