Audiolab 8200 CDQ + Arcam FMJ A19 seem to share same functions with their remote controls which is annoying.If you want to adjust volume both devices respond to the remote controls.Does anybody know how to solve this problem?Thank you.
chebby said:Follow the instructions at the bottom of this document for your amp remote ...
www.arcam.co.uk/ugc/tor/A38/IR Codes/amps_rc.pdf
davedotco said:chebby said:Follow the instructions at the bottom of this document for your amp remote ...
Presumeably you will need another remote that can be set to the same code as the amplifier, or am I missing something?
chebby said:davedotco said:chebby said:Follow the instructions at the bottom of this document for your amp remote ...
That's what the Arcam instructions say.
I didn't claim the OP would like the instructions. (Especially as I imagine spare, re-programmed handsets are expensive.)
Esra said:OK, Yamaha remote seems only able to control other Yamaha devices. Btw. I dont see any button on the A19 or the remote called something like system ... :? There must be a way
I found this one
http://www.arcam.co.uk/ugc/tor/a19/FAQ/a19_faq_issa.pdf
Can anybody explain me more detailed please,,,thanks
