Rega Elex R driving ATC SCM11 (new version)
A friend of mine - is driving ATC SCM 19s with an Elicit R to great effect - check out his posts on the Rega FB page, Richard Plater is his name
Yeah it's a pity, they are quiet hard to track down outside of the UK. Given the potential sale perhaps a dealer could accommodate a shipped home demo. Then again they're not the lightest speakers to be shipping around.
You quite often read about even the Brio r comfortably driving speakers it probably shouldn't be able to. Maybe Rega underrate the power of their amps. This is often said of Naim too and they are not entirely dissimilar.
Do you? I've read many times about the Brio-R powering Totem speakers but ATC/Rega is a new one on me.
Romulus said:
Rick the HiFi dealer clearly confirms that the NAD C32BEE (power out put only 50 watts per channel) drives the SCM 11 (he does not specify which version?) and SCM 40 speakers without problems.
Hi Romulus
I've used the C325BEE with SCM7 MK2, SCM11 MK1, SCM19 MK1, SCM40 MK1 and now with the current (curved) SCM7 MK3, SCM11 MK2, SCM19 MK2 and SCM40 MK2 passive monitors.
We've also got some clients using Arcam Mini Solo with SCM40 MK1 passive monitors.
All the best
Rick @ Musicraft
Not specifically Rega/ATC but definitely I've read that in a number of reviews and forums. I'm not proposing that the Elex r is getting the best out of the SCM11s, but I think the SCM11s are so good they're probably getting the best out of the Elex r if that makes sense? I've never been so glued to any set up I've had. A couple of weeks ago I added an irdac to the system for purely practical reasons because it has plenty of inputs that I needed. Having used one in previous set ups I wasn't looking for a big sound improvement, but I knew it didn't do anything bad either. I was amazed at the unexpected improvement, it was like flicking a switch labelled "soundstage and detail". Again I put this down to the ATCs getting the best from the electronics.
I presume you are refering to the Brio R PP ? The Elciit R has plenty of power on tap and is more than capable of drving the ATCs with excellent results !
Northern Ireland is in the UK, but there are times when it doesn't feel like it.
curved SCM11 passive monitors - What Hi-Fi Awards 2015 winner for Best standmount loudspeakers £800 - £1200
WHF Award winners for three consecutive years
Rick @ Musicraft
This thread highlights the difficulty in power matching, there isn't a simple rule other than you can't have too much power.
Any amp will pretty much drive any speakers, the critical question is how loud to you want to go? If it's just going to be background / low levels in a small room then a 50w amp would be adequate. However if you want stadium levels in a large room it won't. The reason atc speakers need a more powerful amp than most is because they are below average sensitivity, so they need plenty of volts to generate a high SPL. In simple terms, higher power rating means a higher voltage gain. They don't need huge current reserves as their impedance is relatively flat. What you don't want to do it try and achieve disco levels with your Rega, it would likely damage the speakers.
MUSICRAFT said:
curved SCM11 passive monitors - What Hi-Fi Awards 2015 winner for Best standmount loudspeakers £800 - £1200 WHF Award winners for three consecutive years
Rick @ Musicraft
You missed the Elex-R (best amp £700 - £1000).
Don't you sell that as well?
Thanks for advice but disco levels not required, or wanted for that matter. I value my hearing. With this combo so much detail and energy comes through at moderate volume you don't feel the need to crank it up anyway. I listen in a smallish room and with the volume dial at 10 o'clock position it fills the room. SCM11s have lovely dispersion, sound really travels from them, very generous sweet spot.
chebby said:
Rick @ Musicraft
Hi chebby
Yes, we also support Rega.
All the best
Rick @ Musicraft
chebby said:
Rick @ Musicraft
play nice Chebby pmsl
Yup, I know. I heard the Elicit-R driving a pair of PMC 23s. Very good. But the Elex-R with ATCs for all formats and living with it on a daily basis? That'd be down to the OP to have a home dem and deciding.
Why not? Check the "what is a powerful amp" thread. I see no issues here.
No reason why not, but given the Elex is borderline on paper, at least, and the ATCs not the most benevolent with lower powered amps, it's always best to try one at home.
When I use my TT the cartridge is a low MV and requires extra volume, as does the Blu-Ray player when played thru the amp (and my speakers are relatively easy to drive by comparison). There's no right or wrong solution: It's right if it gives you sufficient volume thru all formats and 'wrong' if it doesn't.
What about SCM19 with the Elex-r, powerful enought? I will try to find an audition for this kind of money.. the new color satin black make it even more interesting. I'm seeking really good soundstage and more musicality compare to my other speakers.
Got the amp myself but It seems that it can't drive my biggest speakers Jbl studio 290 as I want when they make a loud click noise when I play with high volume but they do give me a nicer soundstage then my smaller Monitor audio bronze 2, I can also crack up a pair wharfedale diamond 155 with no noises.
Given those speakers have a spec of 91db/ 8ohm I can't imagine the Elex r having trouble driving them unless you're playing at extremely high volumes. What position is the volume dial at when you hear the clicks?
11 clock with no equalizer, for example at the beginning with this song https://open.spotify.com/track/4wpdef5ZvBxdtevmijrXHQ
when tested with my other amp Marantz pm6004 it punch same if not maybe slightly more with no noise, It seems that the noise appears when there is sudden "attack" in the sound at high volume?
I seem to remember in the WHF review of the Naim Unitiqute which is only 40 watts per channel they drove all sorts of expensive speakers without any problem so I would think that that the Rega would be fine.
