My setup is marantz pm6005 and q acoustics concept 20. The sound is good and detailed, but it really lacks punch. I have heard that the nad 3020 could give me what i am wanting. Any thoughts guys? :rockout:
ISAC69 said:Maybe you have to change to floorstander speakers :quest: What is the size of your room ?
Also an optical cable is not the ideal one for music listening try to demo a good RCA cable one .
MUSICRAFT said:Hi Chr78
I'll recommend that you should also consider Monitor Audio's new A100 amplifierThe A100 should be available fairly soon.
All the best
Rick @ Musicraft
davedotco said:If you can afford it and if you can find one, a Creek 50A with onboard dac module.
Not cheap but a real, serious improvement.
chebby said:davedotco said:If you can afford it and if you can find one, a Creek 50A with onboard dac module.
The Creek Ruby DAC module will not be available for a while yet. Probably another few months.
relocated said:ISAC69 said:Maybe you have to change to floorstander speakers :quest: What is the size of your room ?
Utter rubbish!
ISAC69 said:relocated said:ISAC69 said:Maybe you have to change to floorstander speakers :quest: What is the size of your room ?
Utter rubbish!
I see that your system bellow is quite rubbbish for music...
Apple Lossless - ATV3 - AVI ADM 40 also ATV3 into AVI ADM 9T [my wife's system]
and Grado SR80i
lpv said:ISAC69 said:relocated said:ISAC69 said:Maybe you have to change to floorstander speakers :quest: What is the size of your room ?
Utter rubbish!
and Grado SR80i
:clap:
:rofl:
Utter rubbish!
and Grado SR80i
Cypher said:MUSICRAFT said:Hi Chr78
All the best
Rick @ Musicraft
Hello Rick,
Could you tell me more about the A100 ? I've been waiting to try this one out but it's not available in Holland yet.
Have you heard one already ?
the record spot said:ISAC69 said:relocated said:ISAC69 said:Maybe you have to change to floorstander speakers :quest: What is the size of your room ?
Utter rubbish!
and Grado SR80i
Optical cables are absolutely fine for music listening. I use one as well as more typical phono cables into my amp. Isac's later post was additional nonsense.
Audiophiles like that are in the minority. Great audio is easily had these days, is not the preserve of the golden eared and many of the old rules and perceived wisdoms have thankfully been kicked into the long grass.
ISAC69 said:Also an optical cable is not the ideal one for music
