Hi
Just bought a Sony DAV DZ260 ,and when i try to watch tv the sound is just like when you have no aerial plugged in,i.e a loud hiss
I think it may have something to do with my old TV set that i am about to replace
here is my set up at the moment
Very old Panasonic TV (Just bought this Samsung LE40A686M1 for £700 with 5yr warranty)
I have one of those infrared signal transmmitters which i am using to send the SKY tv signal from another room into the TV which has the suround sound system connected,this uses a scart input into the back of the panasonic),i.e into AV1
The cinema sound system plugs into AV2,i can watch DVD fine,and the sound is ok,but as soon as i watch TV i have the problem described earlier
I would like when watching TV via the Signal transmitter to beable to use the Surround kit to listen to the TV
Is this because i am using 2 separate AV inputs for the 2 different things?,i.e TV and cinema kit?
I have just ordered an Optical cable,as i guess i will need ones of these
Knd regards
Dean
Knd regards
Dean
