Okay, so my system is in my bedroom, and I have two power sockets in there. One is used for the amplifier, which is a Rotel RA04, and the other is an extension leading to a PC, monitor and turntable. All the power in my room is, according to the wiring diagrams for the house, itself an extension from the next room along which has a few electrical items such as lamps, clocks, hairdryers, a TV and DVD player on the go. If everything is turned on at the same time, the power cuts out and I have to switch it back on downstairs in the fuse box, which usually happens about once every two months, which is probably bad but not too much of a hassel.
Is this wiring set up probably impacting the performance of my amp / PC? Is there any better alternative set up anyone can recommend? I thought plugging the amp in to the wall rather than the extension cable would be a better idea, but seeings as the wall socket is mearly an extension from the next room along is this helping?
All the wiring in my house is contained in little copper pipes which aparently is a good thing.
