Question What do you use for power
Dom
1,206
468
19,570
At the moment I am using a basic Robert Dyas 8 socket surge protected extension which is fine. For my birthday I will start using an Eaton 8 socket low noise 510w UPS. Hopefully it will be better for audio needs because its low noise.
I was wondering what you nice people use to power your hifi.
Samd
303
147
19,070
All my 'kit' goes through a protected power strip which itself plugs into a wifi socket which plugs into a wall socket. The wifi socket switches everything off at midnight till 1130 the following day. I would be interested if you discern a difference.
Dom
1,206
468
19,570
It could be tonally different. I will let you know.
Dom
1,206
468
19,570
I use a tacima 6 way surge protection and conditioner.
Plugged into the wall socket
There quite good for the money for what you get, it absorbs a surge using 3 over-sized MOV's, gas tube protection and a thermal fuse. It conditions using a toroidal choke coil EMI filter and has a screened mains lead. Not bad :)
Reactions: aversaurus
record_spot
285
169
19,070
Standard plugs, no boutique connects, and a couple of Masterplug adapters to give me additional plug connections. Beyond that, it's all stock.
abacus
1,073
786
20,070
10 way surge protected power strip, anything else is superfluous for 99% of the population. (Power system in the UK is pretty good)
If there is a major problem get a re-generator, as conditioners (No matter the price) are useless and any changes in sound are purely placebo. (Just do a double Blind test for proof) Also a lot of the magic HI Fi stuff has not been tested for safety so should be avoided at all costs.
Bill
twinkletoes
408
265
1,270
If you want proper clean power spend money on a battery backup like those used for computers. Or as others have stated a power plant/regenerator like those sold by PS audio very expsensive.
My Sugden a21 draws a lot of power so that goes straight in the wall, lower-powered devices are on a strip that came from wilko for 3 quid 20 years ago. Power is power THOUGH i find things sound better when not ganged up on power blocks and extensions and it is very noticeable, especially for high-power items
Timbola
22
13
Tacima 6 way power conditioner for DAC & Streamer. Amp goes straight into the wall.
I notice a positive difference of less noise with the DAC & Streamer plugged into the Tacima.
I notice a negative difference (strangled dynamics) if I plug the amp into the Tacima.
Reactions: Al ears and Dom
