Native_bon said:Oh yes they do. I agree with you to some extend with cables, but mains conditioners really do affect sound. I had an Isol 8 mains conditional & it changed the sound, but it was for the worst.
Oh well same experience from both of us. I know how it sounds, cause I feed the same when people say it about cables, but this was really night & day.CnoEvil said:Native_bon said:Oh yes they do. I agree with you to some extend with cables, but mains conditioners really do affect sound. I had an Isol 8 mains conditional & it changed the sound, but it was for the worst.
I also tried an Isol 8 and found much the same thing.
TrevC said:Think what would happen if lousy quality interference ridden mains translated directly into poor sound quality. It doesn't because all traces of interference are removed in the power supply of the amplifier.
The bottom line is that you are mistaken.
That may well be the case. But dnt know about the science bit.Vladimir said:The general street knowledge about power conditioners is that they limit the current to the amp and this manifests as lacking in bass, dry sound etc. Any science to back this up?
I suppect the filters in the conditional bottlenecking, cause if you go pass the recommended handling power..e.g amplifier, this can be a problem. This much i know for a fact.Vladimir said:If this was the case, the power conditioner fuse (5A or 10A or 15A...) would blow if the amp sucks more current than its rating. No?
If I check the fuse rating on my amp, and it is 10A, then the fuse rating on the power conditioner should be above that and there should be no bottleneck? Or does it depend on the active/passive filtering in the power conditioner?
Any of the forum techs to give us few clues, even theoretically, would be appreciated.
CnoEvil said:TrevC said:Think what would happen if lousy quality interference ridden mains translated directly into poor sound quality. It doesn't because all traces of interference are removed in the power supply of the amplifier.
Silly me for forgetting myself. If it wasn't for you, I would actually believe what I'm hearing...and that would never do.
Keep up the good work.
Native_bon said:I suppect the filters in the conditional bottlenecking, cause if you go pass the recommended handling power..e.g amplifier, this can be a problem. This much i know for a fact.Vladimir said:If this was the case, the power conditioner fuse (5A or 10A or 15A...) would blow if the amp sucks more current than its rating. No?
TrevC said:Vladimir said:If this was the case, the power conditioner fuse (5A or 10A or 15A...) would blow if the amp sucks more current than its rating. No?
You would have to exceed the average power rating, by which time you would probably be deaf or have wrecked speakers.
Vladimir said:TrevC said:Vladimir said:If this was the case, the power conditioner fuse (5A or 10A or 15A...) would blow if the amp sucks more current than its rating. No?
5A x 230V = 1150VA, which is far beyond what a typical home hi-fi amp would use even in peaks. If 5A is all we need, I don't see how a well built power filter like that ISOL-8 fails to deliver such modest current.
CnoEvil said:Vladimir said:TrevC said:Vladimir said:If this was the case, the power conditioner fuse (5A or 10A or 15A...) would blow if the amp sucks more current than its rating. No?
Nobody's arguing with you.
The only thing that NB and I have said, is that we didn' like how our systems sounded when plugged into it....it was simply a warning to the OP that these devices may not always bring an improvement.
Hum.. I thought we would be expecting it to make our systems sound better not worse..? So I think thats a very good question.. Am certain our experiences were real cause the opposite happened.Vladimir said:CnoEvil said:Vladimir said:TrevC said:Vladimir said:If this was the case, the power conditioner fuse (5A or 10A or 15A...) would blow if the amp sucks more current than its rating. No?
I have the exact same experience. The question is did we hear an actual change or was it expectation bias.
Vladimir said:I have the exact same experience. The question is did we hear an actual change or was it expectation bias.
Same here, Had 60day trial if i can remember correctly.CnoEvil said:Vladimir said:I have the exact same experience. The question is did we hear an actual change or was it expectation bias.
In my case, it was an expensive bit of kit that was being sold at a very good price....in fact, IIRC, it was a mains regenerator.
If anything, my expectation was that it would improve the sound....but it made my system sound overly clean, bright and analytical. Since it was on trial, I took it back.
Ok get your point. I never read about the bad reviews from indiividauls. I read about the good reviews from mags. also knowing I could return if not satisfied I decided to take the plunge but was not to my liking.Vladimir said:I bought an AVR for safety of my equipment after few issues with few appliences burning out (it was an old house). Then I read on forums how it has negative effect on sound quality for most people, even with expensive conditioners. After that I auditioned with and without the AVR and heard differences. As others described, the sound was dry, weak on bass and not as full. After few days I tried it again and heard no change, so I decided to keep using it and ascribe the previosly heard diffeences as expectation bias.
