I have had the Pioneer PDP428 for three weeks - bought it off the back of all the rave reviews it received. Whilst pictures from freeview, upscaled standard def DVD's and SKY HD are generally excellent there is one area that the set seems to let itself down on.
When watching football - either standard def or high def on SKY - when the camera pans quickly from one side of the pitch to the other there seems to be an annoying unsmooth movement/jerkiness of the players. You can see a similar problem with cricket.
I have been through the menus and have switched on/off the pure cinema mode - with it on it makes the problem worse but even with it off the jerkiness is still there. I don't think this problem is specific to my set as I have checked and have seen the same problem in John Lewis.
Has anyone noticed this problem or found a solution ?
A question for the What Hifi team - do you look at sport as part of your review process and if so did you notice this characteristic on the Pioneer ?
