Andrewjvt said:
Active v passive sound quality test to be conducted today The results to follow after.
The main question that needs answering is: can set up costing 3 - 4 times cheaper beat my current system for sound quality. If it can then by how much? And also if it is much better, am i ready to make some hard choices - go for the best sound and ignore any brand attachements?
I'll either be building passive k100 kits (scm 100 clones) or going active.
Sound quality being the most important thing above all else.
I hope you will all enjoy the results that follow over next few days
Look forward to reading your impressions. Not sure about putting them up against something 3-4 times the price. Sounds like you may be setting them up to fail.
When I recommend actives to people it's usually to do with value for money at the budget end of the scale, but I'm often reluctant to for a living room setup because, especially for beginners, they're trickier to setup. It's hard to get the connectivity options you get with a regular integrated amp/passive speaker setup. They tend to be pretty ugly.
Then there's the boring semantic bit about "better". I'm a boring person so I'd accept "better" if they measured better, but that may have little bearing on whether one likes how they sound. I prefer the sound of my active setup to my previous passive setup, but that's just personal preference. I like the presentation of active speakers and they sound the most balanced to me, but that's no guarantee that others will like it. Seeing as you like ATCs it might be a presentation suited to you, but despite claims of ultimate accuracy and detail, etc. they are compromised just like any speaker and different makes do sound different.
