Panasonic TH-37PX70 HD Picture Quality. Please help Clare!
Please help! I want to upgrade from my 24" CRT, and as I sit about 3m from the screen, felt a 37" would be the best size. I am really tempted to buy the Panasonic TH-37PX70, but am really worried that the HD picture quality won't be amazing enough! It's really important to me that the quality of SD programming is good, but unless the HD picture Wows me wouldn't it be better to stick with my old CRT?
I'd really aprreciate your views. Does it perform well with HD sources and will I notice a significant difference from SD sources on this TV? I intend to use good quality cables if that helps. I will be using the QED Quinex HDMI Cable and Philex SLX Gold Scart Cables.
Thank you for your time
Clare Newsome
1,657
You certainly will notice the difference with a good HD source - the Pana's ability with motion, colours and contrast are second-to-none at this screen-size. It'll certainly impress you after a 24in CRT, however good.
