Optical vs Coax SBT>Rega DAC
stevebrock
183
Well I have 2 Mark Grant digital coax cables going into my rega DAC from my SBT & CDP
i have ordered a optical cable form thatcable and see if any difference can be heard!
anybody have any opinion or is it just a cable and shouldn't make any difference whatsoever?
sorry if this has been done before.
In my case i prefer coax, i don't like the Fit of the optical cable, it seems fragile.
I've no knowledge about the differences in sound quality of Rega DAC/SBT.
HI Steve - they sound different thats for sure, to me the stand-out difference is the co-ax sounds a bit warmer than the optical BUT only on certain material - on some material the optical output seems 'quicker' so I prefer the optical. I have an Arcam rDac and I have both outputs connected to a Yamaha AS500 amp so I can switch between the two for instant comparison.
The AS500 is known for being 'quick' and Arcam is on the warm side of neutral so it might just be the gear I have being able to show both sides of things. The IPL's I have are transmission line design with a ribbon tweeter and they definitely show the difference.
Hi-fi's a funny thing as we all know, for the price of an optical cable its definitely worth trying out.
Yamaha CD300 / Arcam rDac / Yamaha AS500 / IPL S4tl bi-wired co-ax, and silver PTFE
yes that's what I thought so I ordered one from thatcable.co.uk to see if there is any difference!
There is, hope you can spot it! Thatcable is where I go, too!
Hi-FiOutlaw said:
stevebrock said:
Not sure what you mean by that, I've never used the SBT without my rega DAC
What i meant is the differences in sound quality between coax/optical using Rega DAC/SBT.
sorry I get you now I will let you know if there is any!
I do not have a Dac for my SBT yet, would be intrigued to see what differences you notice.I was staggered how good it sounds and not sure how much I need a dac.
I am just running mine direct into my Caspian using the supplied RCA cable, tried a Chord crimson but prefered the supplied one ( and its longer).
I am so happy with this purchase, hope you are enjoying your new toy as much as I am.
Have fun. :grin:
Just a thought Coax is the way I would go, as you cut out encoding digital to light and decoding light back to digital. Also with coax you have a greater choice to adjust the tonal balance of the system if to bright or to dull etc 🙂
how does that work then re: tonal bbalance
yes I agree with RCA interconnects but not a digital coax or am I missing something
LOL....
my bet is you'll notice the coax sounds better, the optical cable to sound thinner, less or lean as though frequencies are missing. I only have the freebie optical cable I got with the Xbox and its what I found was the differrence between copper and glass.
Please comeback and let us know your findings
You're not missing something. Think about it, how could a digital cable (optical or coax) selectively change the fequency response?
well my optical cable came today!
iMac>SBT>optical cable>Rega DAC playing FLAC Dire Straits - Brothers in Arms
Marantz CD6004>Coax cable>Rega DAC playing Red Book CD Dire Straits - Brothers in Arms
I CAN NOT TELL THEM APART
EEEEEEEERRRRRRRRRRRRRRMMMMMMMMMMMMM, isn't thepoint that you compare the cables in the same set-up? :doh:
It's a harmless and interesting test when the cables haven't cost you much money. However I pity those poor souls who attempt the same thing using very costly cables, or who genuinely believe that you can alter the 'tone' of 1's and 2's by using different wire.
I tried both Coaxial and Optical from SBT to my rDAC and to the Coaxial was more detailed and balanced than Coaxial (to my ear), tried the same blind test in different times and music and now am turned to using, both cables are not expensive Optical is Belkin and Coax is Monster.
I think that might be 1s and 0s. :read:
Could you have a quick edit to allow us to know exactly what you mean?
What was the test....
did you try both cables via the CD player?
or was it two seperate sources with each cable?
i tried both cables with both sources
now i have had time to listen i think the coaxial sounds smoother and is the preference!
so is the cd player going through the dacs also running as a transport only.
and have you tried them via the 667 - I know I heard distinct differences via coax and optical through my AV amps inputs, just curious.
