A admin_exported New member Aug 10, 2019 2,556 5 0 Aug 19, 2009 #1 When a choice is available, is it generally better to go for Coaxial or Optical digital connections? ... or is there any noticeable difference?
M matengawhat Well-known member Aug 17, 2007 698 16 18,895 Aug 19, 2009 #2 coaxial as no conversion involved
Dave_ Well-known member Jul 31, 2008 1,589 886 20,570 Aug 19, 2009 #3 Theoretically, coaxial should be better than optical as there is no conversion going on, but personally doubt you'd hear the difference. Though,if you have both,you could alway's compare them for youself...
A Andrew Everard New member May 30, 2007 1,878 2 0 Aug 19, 2009 #4 Although optical does have the advantage of no direct electrical connection between the two units, which can have a bearing on ground loop/hum problems, and noise on the digital signal.
