Been looking at ebay recently for bargain 2nd hand stereo amps from the late 1990's to try with my Denon AVR 2310 and KEF Q500's....
I'm just keen to see what difference there is between a good, but older (and hopefully cheaper!!) stereo amp over modern av receivers. After all stereo amps haven't changed in performance by a massive amount in the past decade, right?
Anyway, I completely forgot that my old Pioneer A-605R (5 star review...1998ish!!!) is sitting in my parent's lounge collecting dust.
I'm going to collect it off them over the weekend and power it up and give it time to settle, as it probably hasn't been used for 5 years.(Hopefully still works!!). I will post my findings on here.....
Anyway, my question (not seen manual yet) is this:
The Pioneer, from memory, can power two sets of speakers. Does this mean I can disconnect my Q500's, that are bi amped to the Denon, and use all 8 banana plugs to plug into the two sets of speaker terminals on the back of the Pioneer? In effect using the Pioneer's ability to drive four speakers, but in this case only two speakers being 'bi amped'???
The KEF Q500's are rated at 8 ohms.....
Anyone?
EDIT: Pioneer A-605R is more like a 1994 model, not 1998......time flies!!!
Anyone?
