New Tt choice
Flux
6
Hi all, I'm looking to replace my Systemdek Transcription turntable after over 25 years, painted about 3 years ago as the nextel finish was starting to look worn.
I'm considering either pro ject 6 perspex superpack or Rega Planar 8 with Apheta 3 . One of my considerations is vibration isolation as the tt is upstairs so on floorboards and I'm often doing weights whilst playing the tt and whilst I'm not just dropping/smashing the weights down I'm very conscious of making the record skip. Has anyone got experience or opinions on either of these or any other options that would fit the bill, don't really want to spend more than £3k as I also need to buy a phono preamp (again any advice would be welcome)...
I'm not going to advise on turntables at the end of the day it's just a platter spinning around, but as far as isolation is concerned, which is probably more the issue you need to deal with. I'm using the iso acoustics indigo orea under my Avid ingenium turntable with great effect, my turntable is in the living room and we have floorboards /carpet, when my wife walks past the turntable (without even a hint of tiptoe or light footed-ness) the cartridge would jump a couple of times, after installing the iso acoustics....not a jump, wobble or anything, the Avid ingenium also has large Sorbothane padded feet which might also be advantageous....just something to consider along with a new turntable if it doesn't happen to have it's own suspension system.
Reactions: Flux and Al ears
Just looked at the isoacoustics feet you mentioned skinnypuppy71, I did wonder if something like this could be a viable solution so thanks for the recommendation they look spot on.
Reactions: skinnypuppy71
Obviously, any TT with suspension will have an immediate advantage.
Otherwise you can add something like a Townshend seismic sink or similar to an unsuspended deck ie. Rega/Technics.
A wall mounted shelf would help too.
Good luck
Reactions: nopiano
Some good thoughts here, thanks. I'm leaning more towards the Rega. Unfortunately the wall shelf is a non starter in the room I've got.
I haven't owned a turntable for over thirty years but I do recall the best way to eliminate vibrations is to have it stacked on a special wall shelving - best results are on solid walls, not the ones that have plasterboard panels. 🙂
I had my DM101 Logic turntable installed on a wall shelf, similar to the one below.
why all today say it´s just a platter to spin the records so Thorens, Garrard and many other brands were wrong a badly built lightened thing is better than a thik platter made of aluminium as 40 years of development(this ´till 1979)were for nothing,
buying, as i bought in the 80´s two turntables (Technics SL-M1 and Pioneer PL-707) and one in the 90´s (thorenz TD2001) all are in need or repair but i´m using either than the two new ones, all that i already had in 1979.
to be more acurate i have a 77 technics with the 207C cartridge that refuses to stop working and releases a, perfect sound from the records played there no matter the grroves being tighter or larger inbetween them, and the old turntables are bad , for the brands
as they work perfect for more than 50 years and while they work ,the brands will sell only some that started to play vinil records and they say" i do it because of the ritual"
a Pl-100 from pioneer is excatelly the same as the TD2001 by thorens, personalized . Everyone in the world was wrong only today one really knows that the cheapest turntable reproduces the same sound as the Nagra aniversary edition,
cartridges, we have the 2m red the best of all times and they used to say "the black is the best !" sponsered by Ortofon (but Ortofon i know it at least since 1977 so how can they be good if they are old technology)
and i read "obvioully we need a suspenction" , so what in reality is needed ,
a rega arm was told that was very good ,i looked at it and thought the anti-skating in it was a really badly done, built with plastic parts and not acurate at all , if not just bought now, what about the cheese IKEA board of wood why is seen all around the world,
rooms are so tight that one would need a shelf to put the turntable, it´s the future today ,
but if some turntables cost 500.000€ or more i think isn´t incorrect to say that they are good because if they keep being released it´s only because some do buy them(dubai), so i´m still thinking if what i used to know is at all correct? please teach me, i want to know how to read my vinil records that after colecting for 40 years plus my father´s collection ,
what can i use to play them, i have already 56 turntables that were considered good or very good but it seems that they are old and bad? am i going to buy a debut from Pro-Ject and get what no excelent turntable could do more than 40 years ago?
wasn´t vinil a thing of the past, graphics showed prove that cds have better sound, more dynamic but why they sound so bad compared to the vinil version , i can´t buy more cd players ,have enough what am i missing has it seems i´m always wrong.1000000873.jpg1000000876.jpg
this were my two last systems i assembled in a dinning room in my family house because my mother lives there and she´s old but i staying there at night i had to have music but a litle room only ,having what i call a colection i opened some boxes and found this ,some speakers are not even conected but in my two persons couch both systems sound good to me, with i have to admit , badly positioned speakers, B&W, Mission, JBL and Pioneer, others aren´t conected, the laptop is there because i have spotify and at home i have a streamer and if you notice a big cable from the system on the bottom is to connect to it ,a independent system, to the laptop. there is the left one and the right one, in the midle is my new smart tv ,a LG one but not seen
wasn´t vinil a thing of the past, graphics showed prove that cds have better sound, more dynamic but why they sound so bad compared to the vinil version , i can´t buy more cd players ,have enough what am i missing has it seems i´m always wrong.View attachment 9724View attachment 9725
Well I read all that but still don't see how it answers the OPs question....
Reactions: Rui
The bottom shelf and turntable setup looks great but I always wonder how they get the record to turn without any power lead. Or, indeed, how they get any sound without phono leads. Still, why risk the aesthetics?
Reactions: Jasonovich and Gray
Well, I've chosen, I listened to both TT back to back with my amp and speakers playing a wide variety of my music and although the Rega may well have been more accurate I enjoyed the project one more so I've bought that with some new speakers and a ds3b phono stage, hopefully will be picking up in a few days.
i was under 47 degrees when writting that i think i went out of the main subject also repeated myself , only after three days with this temperature that not even at night it feels a bit more fresh one gets confused. Air conditioned only in the car and at home , i was working in the countryside doing some prevention to try to not have a big fire with tall dried plants covering the fields, inside a agricultural warehouse inside a pre-fabricated office in the warehouse, today´s the same, already 33 degrees with grey sky
I feel for you. I was living in Spain last year and it was HOT.
Ouch!
Reactions: Rui
