NAD or REGA + Dali Lektor 6
ELVIZ
Hi all,
I'm looking to buy new audio equipement and have tested 2 combinations in a shop. The guys suggested me these 2 options:
Combination 1:
NAD C356BEE + NAD C546BEE + REGA RP3 + DALI LEKTOR 6
Combination 2:
REGA BRIO R + REGA APOLLO R + REGA RP3 + DALI LEKTOR 6
Which one of these 2 combinations would you suggest? Or do you have other combinations to suggest (amp, CD player, turntable and speakers)?
I'm a novice so need some opinions. When listening to it in the shop I noticed that the DALI speakers had a great sound, very clean, clear and defined but were lacking a bit of bass. Is there something to do here?
I listen to a wide range of music: a lot of Jazz on Vinyl, older stuff as Pink Floyd, Beatles, Rolling Stones, Talking Heads, Rock, Pop, Indie and Afro Beat.
The room is +/- 5m x 3m
My budget is not too high 😉
Thanks in advance.
Cheers,
ELVIZ
Hi
If the TT is going to be a RP3 then the amp "MUST" be the Rega Brio R is a killing combo!
For the speakers I've never heard Dali but only read good things!
But why not go for a all in one... REGA Amp, CD player, TT and RS3 speakers...?
And feel that magic working for you...
Best REGArds 😉
I hate repeating myself...... the Rega synergy really is a killer!
If your considering an RP3 TT then get the Brio R - it has a superb phono stage!
