Monitor Audio RS6 and Banana plugs
da_grudge
76
Hello. I just received my MA RS6 pair today. I had a cable with both terminals with banana ends, with my old speakers.
But somehow, with the RS6 I cant connect the banana plugs. There is simply no hole for the banana. Is the only option to get spades or just bare?? I donºt want to buy a new cable now..
Please help asap.
Hi mate,never had those speakers but check if your binding posts have plastic tabs in them, and if they do just poke them out with screwdriver or something.
Hope that helps 😉
Hi not that ive seen the back of the RS6's before but usually you need to pull the little plastic bungs out in the middle red and black ones.
