Eversolo goes nuts
manicm
BANNED
In what way was it clickbait? I just shared a slight bit of enthusiasm and info for Eversolo's new forthcoming products. And I posted this yesterday before WHF got wind.
I'm a big fan of Eversolo, hopefully they'll start to compete in the low end with WiiM.
On the subject of sharing news information, I get it, I do the same 🙂
I use to have much more enthusiasm on WHF with my sharing, sometimes you feel you have been teleported into the show, BBC One - The Grumpy Old Men. I guess it's the classic British cynicism for anything new.
I would say break it to them gently with some sugar coating 🤣 😏
Reactions: manicm
I truly love the concept, imagine, CD(SACD?) player, streamer and amplification and pre-amp MM/MC phono stage. The ability to play your FLAC/DSD files from local storage or NAS. All in one solution, hopefully comes at a sensible price.
I also like the look of the Z10 DAC, do I want to upgrade my Z8, hmmm maybe in a few years when it will be discounted or brought secondhand from eBay.
Whatever happened to Z9?
The pure transport in Chinese speak isn't a CD mechanism, though I could be wrong.
It's what I have Vovofox (also FPGA DAC and media play) and JF MX-Pro, it stores your music files and links to your external DAC/Streamer.
I suspect it'll cost a lot. I like the big display panel, always good for viewing your albums.
Update:
View: https://youtu.be/movF8_Rrr-o?si=-pnIwxxqSE-dPnTm
A bit like this then:
Which probably sets the target price point.
I'm talking about the stupid title... and I've no idea what WHF posted and when because I never read the main site anymore coz of the constant clickbait.
I just noticed the Z10 has R2R, in the blurb there's mention of an AKM chipset. This is interesting, is it both ladder and chipset DAC?
I'm sure more details will emerge, hopefully put this to bed.
Probably like the LAIVs and if I'm correct even the Fiios. They're not true R2R, because the topology does not allow for upsampling, so these are hybrids, probably has circuitry that behaves like R2R, and allows/reroutes for upsampling when selected.
You’re not wrong. It’s the trendy name for a streamer with no built-in DAC. Analogous to CD transport that also needs a DAC added.
As you probably recall, I’m not a great fan of DAC ‘rolling’ , as I’ve found that most manufacturers of CD players or streamers have a fair idea of what sort of DAC is suitable, and it saves yet another box, mains connection and set of cables!
You’re not wrong. It’s the trendy name for a streamer with no built-in DAC. Analogous to CD transport that also need a DAC added.
Digital transport is also management of your music files.
If you have a well equipped streamer, you're likely to have the same functionality.
My Matrix Streamer allows you to play your music SSD/pen drive via USB but you can only navigate using your mobile phone which was a pain.
Hence the need for a separate digital transport.
I prefer to play my stored music directly to the external DAC from the digital transport than using your PC or laptop to do the same.
It's about personal choice.
Reactions: nopiano
Indeed - when I say streaming I usually mean both from (say) a Tidal or Qobuz sub as well as a NAS or suchlike, and possibly a USB drive. However, this shows how garbled the various terminologies have become!
The literal definition of streaming is transmitting/receiving data over a (computer) network. So, LAN or WAN it matters not.
Not unless that drive is connected to say the USB port of a router, or connected to a PC and mounted as network share.
Not really, I'd say the definition is pretty clear, and it's people's understanding of terminology that's the problem...
More news from Darko - see link 🔗 below
More from Darko, Eversolo truly going nuts with their expansion of products but not a bad thing 🙂
View: https://youtu.be/POuWkYM5JEw?si=wln-6Io7Vdh8vMK6
Reactions: manicm
Fair point, but what exactly is a ‘streaming transport’ aside from being a DAC-less streamer? I find these components less obvious that, say, a CD player.
