CS1978 - Just a little advice but your posts are always too vague
If you could put info on such as your overall budget; what type of music you listen to and also if you've any other seperates youre using currently etc... All this would be very helpful
There's a fairly wide range of pre/power combos that would suit the M/A GS10's so more info you can provide; the more feedback we can give
