my speakers are not cheap they cost £1200gasolin said:winiar550 said:Blacksabbath25.The only reason i am selling abrahamsen is mostly that i wanted even more power and control and a bit sharper sound (faster as well) if you know what i mean.I was interested how the hypex class d is all about-heard both configuration abrahamsen pre- plus tho power amps in mono and the abrahamsen pre with nord hypex nc500 dm with the upgraded input boards and sparcos class a opamps and i was blown away by the overal sound quality,control of bass ,details etc. while still remaining quite warm soundig.These hypex class d amps is something special even if they dont look the sound quality is the best i have heard so far.Bear in mind that the speakers we have used were helping a lot (ipl s4tl).I will still say if you preffer a sound signature closer to the valve like in solid state but not wanting to spend a fortune then abrahamsen v20up is the way to go and i dont think you will be disapointed.My advice for you will be -make a demo at Colins house (hes a real gentelman by the way) take all your equipment with you and check for yourself(you might change mind about which direction to go.I bought a hypex nord nc500 full dual mono from Colin (IQ Speakers) with the standard hypex input boards and im already impressed -but its still not the same as i heard there but not jugding at the moment as i have the standard input boards plus using an m-dac as a preamp at the moment.Will try tomorrow with an abrahamsen pre then we will see.
Almost sounds like you need som pro pa speakers (not the chep ones) with high sensitivity and a big crown amp
