stephennic said:Sorry I dont thnk so, when one person who is an engineer who didnt expect any difference says wows and notices straight away , bigger soundstage with depth and hearing more detail. 🙂
MUSICRAFT said:MadSquirrel said:I'm running an Arcam AVR360, not a Krell! 🙂
Hi MadSquirrel
I use a standard mains lead with my Krell FPB600 power amplifier 🙂
All the best
Rick @ Musicraft
MakkaPakka said:stephennic said:Sorry I dont thnk so, when one person who is an engineer who didnt expect any difference says wows and notices straight away , bigger soundstage with depth and hearing more detail. 🙂
You were listening harder the second time around in an attempt to hear a difference.
If you both wrote down what you noticed after the change and compared notes with making any comment to each other first that would be more interesting.
TrevC said:Expectation bias.
matt49 said:TrevC said:Expectation bias.
TrevC, I'd like to know what grounds you have for thinking that expectation bias is in play here. Do you have any psychological expertise?
There are many cognitive biases, and they're very complex. I speak as someone who has some academic knowledge of this field, built up over twenty years or so. I'd be hesitant to accuse anyone of a cognitive bias without good evidence and a full understanding of the subject.
In my experience, amateur psychologists are usually bad psychologists.
Please correct me if I'm wrong.
TrevC said:matt49 said:TrevC said:Expectation bias.
If you pay a ridiculous sum of money for something as simple as a mains lead you expect it to be better or you wouldn't have bought it. It wasn't intended as an insult, it applies to everyone.
stephennic said:Hi,
I didnt pay much for my mains lead and it made an improvement. People just like to share what has helped in improving their hifi system. Its about enjoying the music. I let my ears make the decision. Have a good day.
Steve. 🙂
Electro said:There is a problem with blind testing that I read about on another forum . It is contained in the quote below and makes a lot of sense to me .
I must add these are not my words but a quote from an engineer who is a member of the Audio Engineering Society .
"Blind tests don't work for the simple reason that when you hear system A, your brain remembers details in the music so that you always hear them again even if system B doesn't reproduce it as well. This is a well-known psychological/psychoacoustic affect, at least well-known in the Audio Engineering Society. Those people who rant about ABX testing being the only way haven't got a clue."
Could this be one explanation as to why blind testing rarely seems to deliver any meaningful results that could not have been obtained by chance ?
Covenanter said:Electro said:There is a problem with blind testing that I read about on another forum . It is contained in the quote below and makes a lot of sense to me .
There's an even simpler explanation for the non-meaningful results you talk about. Maybe there's no meaningful difference between the stuff being tested!![]()
Chris
Chris
stephennic said:TrevC said:matt49 said:TrevC said:Expectation bias.
Steve. 🙂
TrevC said:Mains wires can have no effect on sound quality. It isn't possible.
andyjm said:TrevC said:Mains wires can have no effect on sound quality. It isn't possible.
So, let me nail my colours to the mast. It is so easy (and cheap) for any halfway competent amp designer to throw in a couple of caps and maybe an inductor in the incoming mains circuitry in their amp that will completely filter any mains bourne noise that it is difficult to imagine that any of the 'HiFi' amps discussed on these pages wouldn't have similar circuitry fitted. In which case, no amount of fairy dust in the mains cable will make any difference whatsovever.
However, TrevC, it is quite possible for an amp with no filtering circuitry operating in a high RF noise environment to be sensitive to the choice of mains cable. So while it is possible for a mains cable to make a difference, it is very unlikely.
MakkaPakka said:Surely if there's RFI in the mains then it's going to be all the way through the dozens of metres of cheap wires in the walls/under the floors and won't suddenly disappear just because there's one metre of shielded cable on the end.
I've never really seen anyone explain on what basis expensive mains cables are meant to work. Anything bad would surely have got into the earlier part of the chain.
matt49 said:Covenanter said:Electro said:There is a problem with blind testing that I read about on another forum . It is contained in the quote below and makes a lot of sense to me .
Chris
Chris, why do you think your explanation is simpler? Both explanations involve us positing some form of cognitive bias: whether it's the bias that predisposes people to hear the same thing twice or the bias that predisposes people to hear differences in sighted listening tests. Is one really simpler than the other?
:cheers:
Matt
Covenanter said:Occam's razor.
Chris
busb said:TrevC said:matt49 said:TrevC said:Expectation bias.
"Expect, Expect!" (to quote Marvin). As soon as someone expresses an opinion that can't be measured & therefore certified as being THE TRUTH. Someone comes along as says Expectation Bias without any explanation - cool! What name do you put to people's reaction when they expecting to hear a differnce but don't?
davedotco said:MakkaPakka said:Surely if there's RFI in the mains then it's going to be all the way through the dozens of metres of cheap wires in the walls/under the floors and won't suddenly disappear just because there's one metre of shielded cable on the end.
I can only answer anecdotally, the full details are in an earlier post, but in the electrically noisy environment of a hi-fi show the use of an Isotek power conditioner, an early model similar to the EVO3 Aquarius, and a handful of their cables improved the sound of the system significantly.
Maybe it was the isolation provided by the filters in the mains conditioner, I really don't know, but the package as a whole removed a layer of grunge that wrecked the performance of an otherwise very decent system.
