Looking for new amplifier, help needed.
MUSICRAFT said:
insider9 said:
Hi insider9
Rost is also available in Black finish. Fwiw, our new stock of Rost listed @ £700 is in Black finish *smile*
All the best
Rick @ Musicraft
That is a VERY low price. In Belgium the price is €2500.
ErwinC said:
MUSICRAFT said:
insider9 said:
Hi insider9
All the best
Rick @ Musicraft
There is a regular ferry from Antwerp to UK. Passed it a couple of times. Worth a ride to grab that deal from music craft at that price 🙂
MUSICRAFT said:
insider9 said:
 I've not suggested Rost as it's under 100Wpc and only available in white.
Hi insider9
All the best
Rick @ Musicraft
Wow Rick, everything I've read suggested one finish.
Sabbath would probably prefer black anyway 😉
insider9 said:
MUSICRAFT said:
Hi insider9
All the best
Rick @ Musicraft
yes I would but wouldn’t mind the next model up is that the Hegel H160 or H190
ErwinC said:
MUSICRAFT said:
insider9 said:
Hi insider9
All the best
Rick @ Musicraft
Hi ErwinC
Thanks and it follows. UK RRP is £2200. At less then a 1/3 of retail makes the Rost a no brainer. 3 new Hegel Rost amps for the price of 1 and with change to spare *smile*
All the best
Rick @ Musicraft
chris_bates1974 said:
Sorry to hijack, but.... what is a potentiometer, and why would someone not want to have one?
It's another name for the conventional type of volume control that alters volume by moving a wiper along a track of varying electrical resistance. Stereo amps use a dual ganged version and tracking errors can lead to channel inbalances. Contamination between wipers and track can lead to audible problems too.
Electronic volume controls (such as the one on your Cyrus) don't suffer the same problems. That's not to say that channel inbalances are non-exsistent with EV controls, but what there are should be insignificant.
(I've also got a Cyrus amp, so far trouble-free for 16 years, not least because of its volume control and source selection methods).
If you have sensitive speakers and use an amp with a potentiometer, it is sometimes impossible to (fine) control the volume at lower settings with the remote control.
The volume jumps up/down with 2-3dB or more with 1 push on the remote control up/down button.
Denon, Yamaha and some others suffer from this problem.
There is also the problem of inbalance in output between the left and right channel. There can be a difference of 1-2dB between the left and right channel at lower volume settings.
Blacksabbath25 said:
MUSICRAFT said:
Hi insider9
All the best
Rick @ Musicraft
good value for money
Hi Bs25
Just a bit and then some *smile*
All the best
Rick @ Musicraft
insider9 said:
MUSICRAFT said:
Hi insider9
All the best
Rick @ Musicraft
Hi insider9
Rost looks classy in the Black finish *smile*
All the best
Rick @ Musicraft
