Frank Harvey
Esra said:...the only proper way is to upgrade to Kef Blade as I don´t think R and Reference Series are comparable.
I wouldn't go as far as to say the LS50 is better than Reference... 🙂
David@FrankHarvey said:Esra said:...the only proper way is to upgrade to Kef Blade as I don´t think R and Reference Series are comparable.
Esra said:Right,I don´t even meant Ls50 is "better" than R300.It is just not the same,not a match...R300 is not LS50 with bass,none of the R and Reference series either,it´s best match "in big" is the Blade and maybe the mini blade i didn´t heard.
davedotco said:This is classic and a reason why I feel that the 'buy what you like' philosophy is wrongheaded, particularly when taken to extremes.
I appreciate that measurements can be hugely misleading too and manufacturers specs are mostly useless, but I feel that a decent grounding in the way music is produced and replayed in the home can help give you an anchor point that helps you make choices that are genuinly based on qualitative differences.
Most hi-fi, particularly speakers, are chosen on quantitive differences, more bass, less bass, bright treble, dull treble etc etc, and of course these are factors that are hugely influenced by rooms, positioning and similar factors. In many cases they make little difference as the user adjusts to the changed balance in a process known as running in.
If you can, when auditioning new equipment you need to get past these more of this, less of that kind of judgements and find a way to listen that shows you how well or otherwise the music is being played.
Simple example, I was demoing a better preamp to a customer, so we started off with his preamp in the system and played a piece that had an acoustic guitar intro.
Wow, I was impressed, the notes were so crisp and clear that I was thinking that this would be a great track for me to play on my guitar, it was so easy to follow I was sure I could do that.
I then substituted the 'better' preamp and played it again, really disappointing, for me anyway......! As I realised that I could practice the rest of my life and never be able to play to that level, the difference in the quality of the guitar playing was astonishing, a huge qualitative improvement that was made by the better pre-amp.
shkumar4963 said:I guess natural sound is what you would hear if the orchestra was sitting right in front of you. That way you get to hear 3D sound and can place each instrument on the stage. Now as I understand most music is not recorded naturally. Often each instrument is recorded with its own mic and producer mixes it to his liking. 3 effects are inserted electronically.
With that as a background what do we mean by natural sound?
Esra said:very small: up to 10 sqm
small: up to 20 sqm
medium: up to 35 sqm
large: up to 50 sqm
very large: 50sqm +
Freddy58 said:I thought the LS50 sounded 'boxy'. They were being powered by some expensive looking Naim kit.
Esra said:Yes you are right,but 35 to 50 i meant to be large too.In some US areas I think that would be small and in japan maybe a palace.
CnoEvil said:Freddy58 said:I thought the LS50 sounded 'boxy'. They were being powered by some expensive looking Naim kit.
That may have been the problem (imo).
Freddy58 said:CnoEvil said:Freddy58 said:I thought the LS50 sounded 'boxy'. They were being powered by some expensive looking Naim kit.
Tha
Hiya Mr Evil *smile*
Would you elaborate? As I said, I compared with other speakers at the time, some Focal Aria 906's and some PMC Twenty.21's as I recall, and the contrast was quite distinct, to my ears. Please understand, I'm not saying the LS50's are bad speakers, because clearly many are happy with them, I can only voice my opinion, FWIW
