None as far as I know, but I know one changed from a Melco.Andrewjvt said:My last comment in this thread because I don't want to upset the op
David: How many that chose the zennith conducted a blind test?
That was more referring to things like amplifiers, but depending on the design brief, its not inconceivable that a range of digital components will naturally have some sort of signature to it, even if it was down to the tech being used.And how do you manipulate a data stream to create 'a house sound?'
How close do you think a laptop can get to recreating exactly what is on the digital file? How close can it get to a dedicated digital source that has had time and effort put into isolating circuitry, choosing the right components for the job, ensuring correct heat dissipation, reducing noise, etc etc. Most laptops are a jack of all trades that are designed to a budget - they’re like AV receivers - features are more important than quality. I’ve had a few laptops over the years, all Toshiba, and all have been very reliable. My earlier ones were usually between £1k-2k type laptops of 10/15 years ago, with Hartman Kardon sound system which sounded very, very good for a laptop, and build quality was excellent. My current one was £450 about 6 years ago, and whilst it’s been the workhorse that the others have been, the sound is bloody awful, and whilst built well, it’s nothing like the others, and half the weight. I’ve not used any of these as digital sources, but I wouldn’t for one moment expect my current laptop to be able to compete, and not that I’d want it to anyway, as it gets enough use as it is - the last thing I want to do is leave it on 24/7 - it’s noisy enough as it is.Data will either work or cause jitter? If jitter can't be heard using a standard noisy laptop with a particular dac. How will adding better power supply improve the data files of music?
Perception. Expectation. I’ve said before that as individuals, we perceive a difference, whatever that might be. How big that difference is influenced by our perception of the difference and our expectations. We then use our own subjective words to describe this difference and it’s magnitude. Others will read that, perceive it in their own way, and create an expectation in their own mind. This then has an effect on how they perceive the differences they get to hear. To some people, a small difference can have a large affect on how convincing their system sounds. It might just be a shimmer of cymbals, which those listening to tonal balance won’t notice, but that shimmer just opens up a layer of reality to their favourite music. That’s too small a difference for some - they suddenly want to feel the kick drum in their pants, which is quite an unreasonable expectation for two products that sit next to each other in the grand scheme of things.Last one You've touched on very small differences but thats not whats being said by other website hosts. A clear difference, night and day Massive improvement Is what's being said to describe the sound.
Regardless of source, why do Chord’s DACs keep winning awards if they all sound the same and eliminate jitter?Is the dac not meant to handle and sort the data anyway to stop jitter?
davidf said:How close do you think a laptop can get to recreating exactly what is on the digital file? How close can it get to a dedicated digital source that has had time and effort put into isolating circuitry, choosing the right components for the job, ensuring correct heat dissipation, reducing noise, etc etc. Most laptops are a jack of all trades that are designed to a budget - they’re like AV receivers - features are more important than quality.
davidf said:]Regardless of source, why do Chord’s DACs keep winning awards if they all sound the same and eliminate jitter?
Please join in on the digital brawler post.cheeseboy said:davidf said:How close do you think a laptop can get to recreating exactly what is on the digital file? How close can it get to a dedicated digital source that has had time and effort put into isolating circuitry, choosing the right components for the job, ensuring correct heat dissipation, reducing noise, etc etc. Most laptops are a jack of all trades that are designed to a budget - they’re like AV receivers - features are more important than quality.
with all due respect, you've fallen in to the folly that a lot of audiophiles do. the laptop can re-create exactly what is on the digital file, because it's digital. When you are talking about the digital domain it has very very strict rules. These rules are not open to interpretation or analogue audio best practise. Once you pass off that file to process of coverting to analogue, then yes, the things you mention will matter, but purely in the digital domain, it's all the same.
As I've said before, transmitting digital data either works or it doesn't. Please don't forget that it wasn't that long ago most people's internet traffic was literally converted to an audio analogue signal, then sent down the crappy copper wires as an audio analogue signal to be received as an audio analogue signal and then re-converted back to digital. But becasue it's digitial you can do that, as it's either on or off. Similarly so, I could take a piece of music, convert it in to base64, literally print it out on to paper, send it to you via normal snail mail, you could then scan those pages in to a computer and convert it from base64 back in to the music file and will be identical to the file that I used to send to you. If anything goes wrong, the file will not work. There won't be a loss of resolution etc.
Sadly, a lot of audiophiles have tried to shoehorn the best practices they used in the analogue domain to the computer domain, but it just doesn't work like that.
Andrewjvt said:Please join in on the digital brawler post. I hope you don't mind but I've copied your comment over on that one also.
davidf said:I appreciate there's two camps to this sort of thing - those that come from it from the technical standpoint and state there cannot be any difference because the scientific data says there can't be, and those that come at it from their own listening experiences which to them, invalidates the scientific data.
Andrewjvt said:davidf said:Do you mean that is the order the Auralic designer rated the effectiveness of improvements? If so, I’m not sure how that contradicts Innuos. Innuos don’t do Ethernet cables (although I’d have thought you’d have taken issue with that one), and if the “NAS” itself makes the biggest difference, I’m presuming that encapsulates everything as a collective that’s inside the box other than the digital drives. The Innuos models have progressively better power supplies as you move up through the range.Andrewjvt said:If someone technical can explain to me how this can be the case I'd appreciate it.
Auralic owner/designer insists the best sound quality comes from a Nas (ethernet cable) and then followed by internal ssd.
This would seem to contradict innous product.
I think that much of the time, the arguments against cables and digital sources etc seem to be made from the approach that you can’t improve the signal, which isn’t necessarily the best way to look at it. Try it from the angle that you’re trying to “preserve” the original signal without any losses caused by something which is less than perfect - and let’s face it - no hi-fi is “perfect”. If it was, it’d sound like Bono was in your living room. God forbid.So
Please someone with technical knowledge Please explain how data can be made to sound better transporting to the same dac?
Or better put: how to turn data into special 'audiophille' data
I’ve mentioned this before, but I’ve had a few people in about the Innuos products, and they’ve all taken home the ZENith to try out in their own system. All have purchased one model or another from that. One had a home demo of the ZENith SE after loaning my ZENith, and he bought the SE. Now one or two of these people, particularly the latter one I mentioned, are in the data industry in one avenue or another. More than once I’ve been told that they don’t understand how it sounds better as data is data, but there is definitely a difference. They also don’t seem interested in ‘why’ the difference exists, as they’ve heard it in their system. Granted, their systems are the type that are able to appreciate this level of source and show the differences between an SE and a non SE ZENith, but I wasn’t going to argue with him as he knows more about data transfer than I do.
I’ll have to see if I can get together with Innuos and hold an event to show that they do make a difference - maybe a direct comparison of the ZEN Mini against the Statement, or maybe even a standard NAS drive against a Statement - that sort of demo should present a definite appreciable difference for all (through a suitable system). Comparing neighbouring models will be trickier, what we’re trying to do is show that there is a difference, and we need to make this as easily appreciated as possible. Once a difference is confirmed, an individual is then free to research the difference between models they’re likely to purchase.
With AB demos though, many people expect to be blown away by differences, and that is usually the detail that makes for disappointing results. People expect to hear something that sounds totally different, and that’s rarely the case, with anything, particularly when the products are from the same manufacturer. This, I feel, adds a little weight to my theory that many people in demos only listen to tonal balance - the tonal balance between a range of the same manufacturer’s products is most likely to be the same, as it has been designed by the same person, and usually to a ‘house sound’.
I mean how can a innous zen mini be so bad that even a Sonos makes it sound flat? Surely if that's the case they have done this on purpose so you immediately buy the expensive model? Perhaps
Why does my laptop sound just as good as high end cd player transport? (Into the same dac) Sorry Mac
cheeseboy said:davidf said:I appreciate there's two camps to this sort of thing - those that come from it from the technical standpoint and state there cannot be any difference because the scientific data says there can't be, and those that come at it from their own listening experiences which to them, invalidates the scientific data.
Subjective listening experiences do not invalidate scientific data, no matter how much you would like them to. Otherwise I could argue magic is real because I can't explain how they did the trick.
Innuos are very good with this, although I can't say I came across it too many times when ripping around 1,000 albums. Sometimes it's a Gracenote issue, but if it's anything to do with the ZENith, they're very helpful and want to know why it's not coming up with all the data. I had a customer who had two albums that weren't being presented as they should (various artist CDs), and they sorted the problem out for him. It was all deep within the Matrix code.Macspur said:One thing I'm pretty disappointed in, is how many of my albums the Zenith is failing to recognise... some I'm not too surprised at, but I've just put in a Laura Veirs CD who it really should be able to retrieve the info for... I know I can manually add the tags, but could really do without the hassel.
Mac
davidf said:Innuos are very good with this, although I can't say I came across it too many times when ripping around 1,000 albums. Sometimes it's a Gracenote issue, but if it's anything to do with the ZENith, they're very helpful and want to know why it's not coming up with all the data. I had a customer who had two albums that weren't being presented as they should (various artist CDs), and they sorted the problem out for him. It was all deep within the Matrix code.Macspur said:One thing I'm pretty disappointed in, is how many of my albums the Zenith is failing to recognise... some I'm not too surprised at, but I've just put in a Laura Veirs CD who it really should be able to retrieve the info for... I know I can manually add the tags, but could really do without the hassel.
Mac
Good idea. I apologise too, Mac, for taking this rather off piste!Andrewjvt said:I started another thread as to not spoil your new toy. I'd be just as excited as you if one was on its way to me
nopiano said:Good idea. I apologise too, Mac, for taking this rather off piste!Andrewjvt said:I started another thread as to not spoil your new toy. I'd be just as excited as you if one was on its way to me
Macspur said:Hi,
The new Zenith MKII will be here tomorrow, got a bit knocked off as it's a cancelled order.
I had a thorough workout with the demo unit and totally convinced of it's merits and able to access all functions except Roon of course.
Mac
CnoEvil said:Mac, how close to your Electro CDP does it get for SQ.
I am not in the least surprised....but was when I first heard a good streamer. It's something you have to hear for yourself.Macspur said:CnoEvil said:Mac, how close to your Electro CDP does it get for SQ.
Well, that's a good question and I never thought I'd hear something like a streamer as good as the EMC1UP, but I believe the Zenith is really that good... I am mindful when I say that, that it could be a touch of euphoria at having a new toy to play with, but I don't think so.
Mac
