Indoor aerial recommendations?
Hello,
Due to some house building shenanigans I'm going to be forced to use an indoor aerial for 2-3 months. Can anyone recommend one?
They all look so similar in the shop, is that just because they are? I'm assuming that it is unnecessary to get a premium-priced "digital" aerial, as all aerials do the same thing, and I'm thinking that an amplified aerial amplifies both the good adn the bad, therefore not really worth it either. Does anyone have any thoughts?
Thanks,
James
I went for the Telecam TCE 2000. Cost £9.99 and worked a treat. OK so Five is missing, but I guess thats no great surprise, and you do need to move it a bit to get BBC1 perfectly, but the rest are ok. Bargain!
There are some recommended makes at
www.ricability-digitaltv.org.uk
I don't vouch for the accuracy or completeness of this, but it might help.
Gyp
13
Has there been any update on this? I've just moved into a flat and the communal aerial diesn't get freeview so I'm using a "one for all" from Argos, but it's not great :-(
