- Aug 10, 2019
- 2,556
- 5
- 0
Hi
My setup is as follows:
Rega P1 turntable (brand new, it got delivered today)
Rotel RA-820AX intergrated amplifier
Mordaunt Short MS10 speakers
Basically, whatever speaker is plugged into the
left channel output on my amp (both direct speaker and remote speaker),
I get a humming/buzzing out of that speaker. I have tested both
speakers and I get the same thing with both so it can't be a problem
with the speakers. Whenever I unplug either the + or - connection, the
buzzing will stop, so if there is only one input plugged into the
speaker the buzzing/humming doesn't happen (even if I plug the inputs
in the opposite way round, the - into the + and + into the -), it's
basically when both are plugged in that I get the noise. As I say, I
have tried both the direct and remote speaker outputs on my amp and
it's happening with whatever speaker is plugged into the left channel.
Does anyone have any idea what the problem could be? If so, how do I fix it?
Thanks for your help.
