How To
How to Install a QLED TV
Installing or wall mounting a QLED TV is done pretty much in a similar fashion as installing any regular big-screen TV. QLED or Quantum Dot Light Emitting Diode TV is the latest technology that aims to deliver very fine quality graphics. QLEDs are generally mounted on the wall and later can be connected with other media accessories. Here is how you can install a new QLED TV with ease.
Step 1
Place the TV hanger
Place the TV hanger on the back of your TV. Make sure the screw holes align perfectly.
Step 2
Fix the hanger
Fix the hanger on your TV by tightening the screws using a screwdriver.
Step 3
Connect the cables
Connect the cables at their place on the back of the TV.
Step 4
Placing the wall stand/clip
Locate the perfect position of the wall stand/clip and dig holes using a drill machine. To locate the perfect position on the wall requires two people, one should sit at some distance and the other should mark the position with a pencil.
Step 5
Fixing the wall stand/clip
Place the stand at the wall and fix it using fasteners, screws and a screwdriver. Use high-quality fasteners if not already provided in the TV kit.
Step 6
Hang the TV
Hang the TV on the wall by placing the TV hanger on the wall stand/clip. This requires at least two people to hold the TV and place it perfectly on the wall.
Step 7
Complete the installation
Your TV is now mounted on the wall, proceed forward to complete the installation by rotating and aligning it as per requirements to find the perfect angle.
Bravo! You new QLED TV are now installed and ready to use.
