For a few weeks Iv had my Denon 1940 DVD player inside a TV cabinet with closed doors close to my Virgin media V+ box (Virgin cables version of Sky HD)
The Virgin V+ box runs quite hot like the Sky HD box and I recently put my hand on the Denon after playering a movie and the case was very warm. I don't mean so hot you couldn't touch it but very warm.
I looked in the Denon manual and found it states that you should leave 10cm around the player for proper heat disspersal and keep it away from other heat sources OPPS!!
Well now I leave the cabinet door open and turn off the V+ box when using the Denon but I wonder.....
How would I know if any componants in the Denon DVD player have been hurt or damaged in any way due to over heating? The player turns on fine, it plays fine with a great picture so... Id assume no harm done? Are there any tests I can run to see if the player is performing as it should? Does anyone know how an over heating DVD player reacts... symptoms etc?
Any advice or thoughts from those with a decent understanding of moden electronics would be greatly appreciated!? Thx
