Hi-Fi Has A Sweet Spot In Volume
Snooker
122
26
18,620
Do you agree Hi-Fi has a sweet spot when it comes to volume to get maximum impact, without it sounding uncomfortable or distorted of course
My sweet spot is around 68 - 74 dba
Deleted member 201267
Simple answer YES !
Reactions: WayneKerr
I think the sweet spot is having the speakers in the correct position, therefore should hear the sweet spot throughout the decibel range.
Of course, amps tend to come alive at a certain volume level as well as @matthewpianist mentioned how good or bad the recording is. There are other issues that make it sound alive, but speaker position is more important than volume levels IMHO.
Same as movies, which are mixed at a certain level (Reference Level). You can play a film at varying volumes and it can sound ok, even excellent, but on a properly calibrated system, turn that processor to 0dB and it just comes alive.
For audio, we all have a comfortable listening level.
AJM1981
Decibel levels are definitely a thing. “Not eardrum shattering loud but loud enough to have the music being present”. I am lucky to live in a soundproof home.
Toeing in the loudspeakers does something, and is a necessity for ribbon or AMT tweeters which seem almost “laser like” But any other more conventional speakers with hard or soft dome tweeters don’t really seem to have any noticeable directional properties. Not toeing them in even seems to slightly improve the horizontal soundstage. That’s why my Dentons are facing straight and the Evo 4.2s with AMT tweeter are toed in.
Another thing I can enjoy are Upright bass lines in classic Jazz with an active sub woofer. Unfortunately, the subwoofer’s history is too short and not everything is mixed and mastered with a subwoofer in mind. That is why it sounds great at one song and leaky in those frequencies in another. It gets annoying if a subwoofer thumps along with a kick drum in a dance track. Some more modern producers hard cut some frequencies which solves that issue.
