Help choosing a DAC for laptop
Currently I'm using my desktop PC as my main music source in my setup.
I have a Creative X-fi Titanium HD to Temple Audio Bantam Gold to Audioengine P4s
I'm happy with the sound I'm getting from this setup but would like to add an external DAC/soundcard so that I can connect my Bantam up to my Laptop too. Ideally I'd like an integrated headphone amp although this is certainly not a requirement as I only really use headphones for games.
I would like some recommendations as to what I should be looking at and what budget to get an equal or better sound from my Laptop. I looked at the Creative X-fi HD (USB) version it seems to have a fairly well respected DAC chip the AKM AK4396 albeit not supposedly as good as the one in the Titanium which uses a Burr-Brown PCM1794. I'm a bit unclear what I am getting for my money though the X-Fi HD (USB) comes in at around £85 whilst the Audioengine D1 I also looked at apparently uses the same AKM chip but comes in at nearly twice the price.
I have looked at kit from £85 to £300 plus and am getting more and more confused as to what I should be looking for. Toward the top end of my budget I saw the HRT Streamer II+ which as the big brother of the WhatHifi 5 star rated Streamer II I'm assuming should be pretty damn good has the same burr brown dac as my sound card and has a SNR of 120 yet despite being £300 this is still less than my sound card.
Maybe I'm getting too tied up in the specs and numbers rather than what these things sound like, some help and advice would be much appreciated.
quadpatch
860
Definitely don't get too stuck in to the spec. I recently tested the Audiolab M-DAC which has the ESS9018 DAC chip whereas the Resonessance Invicta had only the ESS9016 for the headphones and sounded way better! So it should for the price but my point is the DAC chip alone wont tell you a lot. You will see this crossover in price on the low end too.
I recommend looking at as many reviews as you can and bass the responces on price but if you can test any out before buying that would be a huge advantage (I know that's really hard). I am pretty happy with the 3 that I have although still putting the D7 through it's paces really.
You might find the list of available DAC/amps I made useful, here's a link...
http://www.whathifi.com/forum/dacs/usb-dac-headphone-amplifiers-list?page=2#comment-2711321
Demoing these things does seem difficult especially as most of the ones I am looking at seem to be from online retailers.
Thanks for the list of Dacs looks really useful and gives me plenty of options to look at. The variation in price is confusing though when kit with apparently similiar components varies so much in price. Choosing a soundcard was easy there were basically two to choose from the Asus STX and the X-Fi Titanium HD both are about the same price and spec. With Dacs there are dozens to choose from and go from ridiculoulsy cheap to crazily expensive.
My budget is anything from £100 - £300 so I guess I just need to start there and hunt down some reviews and concentrate on them rather than the specs so much.
shooter
210
You'd be hard pressed to find anything better than the Musical Fidelity M1 dac at that price, top end admittedly. Have a Google and there is plenty of info on them. :)
Thanks for all the suggestions. Some really nice looking kit. Its nice to see some British companies making quality gear and its all very tempting and some promising reviews. However I am thinking, and Andrews suggestion to read the DacMagic review just reinforces this, that I would be wasting my money on something like the Beresford or the DacMagic when I really only need a USB input. I'm unlikely to use the DAC with any other source than a PC or laptop so it feels like my money would be better spent getting the best USB DAC I can for the money rather than an all rounder.
The Streamer II is a srong contender or possibly even the Streamer II+ although I wonder if with my setup I would be able to tell the difference that the extra £140 would be buying. Anyway plenty more options still to look at so back to the forums :)
With respect, lots of customers get too tied up in the DAC chipset used - whilst each one has its own characteristics they are rarely the major factor in the performance of the overall box. It's a bit like saying that sevaral different models of car with the same XYZ engine will drive in exactly the same way - it's just not true.
In the case of designing a DAC you also have to consider the way the master clock signal is recovered, the quality of the internal power supplies, digital filters, analogue filters, headphone amplifiers to name but a few variables. Then the circuit board layout is at least as important when connecting all these things together! An inexperienced engineer can ruin the performance of the best parts in the world if he or she doesn't optimise this.
In the case of a DAC that works with USB from your computer the best performance tends to come from those designs that use ATP (asynchronos transfer protocol) in the USB interface. As far as I know the lowest cost model that does this and provides a headphone amplifier is the new Arcam rPAC. I beleive there is a review inthe latest issue of What Hi-Fi? if that helps. My disclaimer is that I was involved in the design of that product and the Arcam rDAC and DAC33 - but at least you now know that I do this stuff for a living :)
Sincerely,
John Dawson
quadpatch
860
Thanks for coming and explaining a bit about this stuff John! From my relatively limited experience with DACs I can testify that what you said certainly seems to reflect what I have heard.
I have been testing the asynchronous iBasso D7 for a couple of weeks now. It's a bit cheaper than the rPAC (if you don't get charged customs tax) and it's pretty good but it has a lot of issues so I would not really recommend it to anyone. If you are looking at asynchronous DACs in this price range then the rPAC looks like the safest and most attractive option. I will be looking to pick one up as soon as I can but my next puchase will probably be the M-DAC.
