I guess its easy to criticise anything and as I haven't heard them I am certainly not qualified to comment on anything but perceived value on paper!
Furthermore, you do get a (switch mode) power supply with each mono amplifier plus it looks well made. GS is also only a small manufacturer so no economy of scale here.
Still, I personally probably would wait for the (dual mono) stereo power amplifier if such is in development and hopefully pocket some money in the process.
It also lacks that manly factor but as a cyrus owner I am somewhat used to that
It will be interesting to hear your opinion after using these! - I don't know what speakers you use but even with a low 83db/w sensitivity, if the load is not to punishing, 30 or so watts should be sufficient for reasonable volume.
Another factor to consider, especially in comparison with something like the P49, is distortion characteristics at higher volume (and usually, though not always, higher frequencies). At 'loud' volume listening the little mono blocks will operate at their limits whereas the Arcam will only be idling.
Interesting times ahead
