gold connectors
denontillidie
15
hi,
i want to terminate my cable ends at the speaker end of the cable and have been looking at using banana plugs. But these seem quite pricey and wont really fit easily onto the connector block of B&W speakers.
i looked for some alternatives and found forks and rings and all sorts of things. are these alternatives any good, and what do most people use as a diy cable termination?
cheers,
rob
Sizzers
188
shooter69:Banana plugs pricey??
A few pounds, ten tops unless you want Milty which would be a couple of quid each from e-bay.
Try these http://www.maplin.co.uk/module.aspx?moduleno=44099
denontillidie
15
thanks for the responses. i will have a root around down maplins tommorow.
quite shocked by what a difference a fresh termination makes
