Following a few reports of switching issues with the Yamaha RXV3900 receiver and DSP-Z7 AV amplifier, Yamaha is to issue a firmware upgrade for both models shortly.
Here's Yamaha's summary of the issues, which it claims is very rare: it has heard of only one affected UK unit to date:
"Symptom:
When the system is turned off for couple of hours, there are some cases
that the unit shuts down soon after Master Power SW or Main Zone SW is
turned ON.
This symptom does not happen to all units but after checking we have found some units have been affected.
The unit can be powered back ON by unplugging and then plugging the AC cable back in.
Firmware update:
We'll start to upgrade firmware for RXV3900 and DSP-Z7 to fix the following symptom and increase software stability.
The latest firmware will be available in our Web site from early February 2009.
This firmware update can be performed by either USB thumb drive or internet connection.
Our service department will also update this firmware when brought in to a local service centre through any of our dealer networks.
The upgrade firmware confirmation will be made as soon as the firmware is set up on the Yamaha Web site."
We will keep you updated as to when the firmware updates appear.
"Symptom:
turned ON.
Firmware update:
