Firmware update Panasonic DMP BD80
james67
11
Just bought the Alien Anthology blu ray and it refuses to play, downloaded the update from the panasonic website and need to open it and burn to disc , but i'm not sure which programme/application to download , any ideas?
kena
104
If you have downloaded the file for your region to your PC you should have an .EXE file just double click it to allow it to extract and create a folder with the following file PANA_DVD.FRM then just write this file (Not folder & file) to a CD-R and insert into your player and update should run. Do NOT power off player as this could brick the player requiring return to dealer, update could take 5-6 mins to perform update
link to update proc PDF
Note also quote from Panny site
The firmware update disc requires to be created with ISO9660 format. In case you are creating the disc on a Windows Vista PC, Windows Vista standard writing application does NOT support ISO9660 format. Please create with a supporting writing software
james67
11
Doesn't seem to have worked , put the disc in the player , display said "bye" then said l fvu , the ejected the disc.
All in the space of about 2 minutes or less!
How ridiculous. The sooner we see the back of Blu-Ray the better. It's now 4 years old, and still needs adjusting etc etc - assuming your player can do so, in the first place, of course. A truly worthless failure.
kena
104
James,
Maybe it was just quick cos the bye part then other stuff on display is normal. I'm assuming it's 2.5 (Region 2) you are trying to load.
Check what ver is currently on your player by the following -
