floyd droid62 said:
				Electro said:
			If you would like to try something cheap and easy go and buy four of these.
http://www.diy.com/departments/knauf-ekoroll-loft-insulation-l728m-w1140mm-t100mm/182146_BQ.prd
Then place them on their end around the rear or side of the speakers in different positions but leaving a gap between the rolls.
Play some music and be amazed at the difference, you can move them about while the music is playing to obtain the best balance.
It may not be a permanent solution but it will help you understand how bass works in your room.
You could always cover them in fabric for that bespoke acoustic treatment look . *smile*
Believe me it really does work!
The picture below is the starting point you can add more and move them around if you wish.
 great setup if i was single i would have a room like that ,however i live with my wife who is strictly  in charge of the front room ,in a small house with 4 grown up children,i have decided that i am wasting no more money on expensive speakers ,so whats your opinion on dali zensor 3 or wharfedale 220 ?  how do you upload picture on this site?
I am lucky it is my personal man cavern so I do what I like in there *smile*
I experienced a nasty bass null in the centre of my room where I wanted to sit.
The bass was collecting in the corners and not spreading out evenly, if I stood in the corner the bass was very powerful and tight but in the listening position it sounded lacking and not as powerful and deep as it should.
As soon as I put the insulation rolls in the corners the null all but disapeared, I still have more work to do though *smile*
I have no experience of the speakers you mention but I agree with others that have already said that changing the speakers will only make a small difference to the problem .
To upload picture you will need to use a free picture hosting site such as photobucket.
http://s1153.photobucket.com/
You upload your picture to the site then copy the link and add it to your post using the image box in the tools at the top of the comment box.
