Thompsonuxb
- Feb 19, 2012
- 125
- 0
- 0
pauln said:Thompsonuxb said:MakkaPakka said:If your ears can detect depth. 3dness, scale, etc. etc. then why can't a couple of good quality omni-directional microphones hooked up to a recording device?
Level matching means ensuring that the two things you're testing are at the same volume. You cannot compare the relative merits of two sounds if one is louder than the other. I would have thought that was obvious :doh:
sorry to drag this back up, but real life...you all know how it is sometimes.
Anyhoo considering CD/file/record/tape data is fixed and source output is fixed......Makkapakka, no - you try recording with a omni-directional mic, then come back here and tell us if it sounds anything like what you hear coming from your speakers, in your room...... prrrft...
And level matching is stupid, if you are testing two devices against each other then you test them to their limits, to the point just before distortion on the very edge of integrity to the point of..... you get the idea. It's this crazy logic that makes me not take these 'hifi' test seriously. How can anyone consider a test valid if the kit is working well within its spec, whats the point?
if you compare say a 200watt Krell with the Cyrus 6a for example what the Krell could do with a pair of speakers will never be known if its limited to the spec of the Cyrus 6a 40watts - and that would be the basis for someone to claim both amps sound the same?......really?
Why you do you think Harbeth have worded their challenge so carefully.
I suppose you must be a troll. I can't believe that someone posting here about these things doesn't understand how our ears work; specifically regarding their sensitivity to different frequencies as in equal loudness curves. Or do you just reject all science?
Er...no, you're the troll & a crap one at that.
and what are you on about, I'm talking about performance and how it can relate to what we hear from our equ this as nothing to do with science, level matching amps IS stupid.
