Do more expensive amplifiers make a difference?
Page 9 - Seeking answers? Join the What HiFi community: the world's leading independent guide to buying and owning hi-fi and home entertainment products.
DocG said:
I read somewhere that it sounded really good, but it was notoriously unreliable... So that's another level where more expensive amps might make a difference.
I don't think that follows, from what I have read about some more expensive amps.
Covenanter said:
steve_1979 said:
davedotco said:
Do you actually know what a "theory" means in scientific terms?
It is a little different from the bloke at the bar spouting "I have a theory.........'
That's an interesting point because anyone can come up with any theory about anything. 🙂
However for a theory to have credibility in science it need to be backed up by accurate, objective data taken from experiments where the results are consistently repeatable.
Yep, the point about scientific theories is that scientists have become wise enough to know that new evidence can appear at any time and to call things "Laws" as was once the practice is to make their ideas a hostage to fortune. So it is fair to equate, for example, the Law of conservation of energy and the Theory of Relativity. Both have no current evidence agasint them being true but they were named in different eras.
Chris
True enough, but it does run a little deeper than just scientists covering their RSSs.
Science is simply a model, usually mathematical, of an aspect of the real world so at no point however accurate, is it the same as the reality.
It is a model, constructed from the best data available and rigorously tested. Newtons laws of motion, for example, were derived (literally) centurys ago and still stand up in the modern world.
This is at least partly because they, and the mathematics used to derive them, were strongly contested by dissenters at the time and in later years, but they have stood the test of time.
Until Einstein of course, though even he made no attempts to disprove them, just putting forward an alternative model.
davedotco said:
...Science is simply a model, usually mathematical, of an aspect of the real world so at no point however accurate, is it the same as the reality..
I've always liked this quote from Brian Cox:
"To understand the universe you need to speak its language and that language is mathematics."
Thompsonuxb said:
steve_1979 said:
MakkaPakka said:
...I don't know exactly what Harbeth was specifying when it said level matching but in most tests that are carried out (like on the matrix site) the only level matching is the volume.
Yes it's the volume levels of the two amplifiers that Harbeth was referring to.
This can roughly be done by ear but to do it accurately you would need to use a voltmeter and to make sure that the output of both amplifiers is exactly matched.
Yep and depending on how said amps volume is attinuated it could cripple one... stupid test.
It's not stupid at all. You just make sure that the volume levels on both amps is low enough so that neither of them is clipping.
For example you had a 20 watt amp and a 200 watt amp you would first set the volume on the 20 watt amp to a comfortable level where it's not clipping. Then you can set the output of the 200 watt amp to match the output of the 20 watt amp. This way they will both be set at exactly the same volume level and neither of them will have any distortion caused by clipping.
I like the Arthur C Clarke quote, the one that almost appears in my sig.
davedotco said:
David@FrankHarvey said:
pauln said:
I can't believe that someone posting here about these things doesn't understand how our ears work; specifically regarding their sensitivity to different frequencies as in equal loudness curves. Or do you just reject all science?
How do you know that scientists fully understand how our hearing works?
I am pretty sure that scientists do not 'fully understand' how our hearing works.
I am equally sure that they know enough about how our hearing works to understand that it both quite remarkably sensitive, has incredible resolving power yet in other area is unreliable and easily fooled. I do not have a problem with that.
Neither do I but a great number of posters & no doubt lurkers seem to think the idea that our hearing can be "fooled" a gross insult to their intelligence. Show them visual equivalents & they will smile or be amused. Go figure!
I certainly believe our hearing "can" be fooled. That doesn't mean that it's always fooled. It's a hugely effective weapon that allows anyone using it to dismiss anything they like, based on expectation bias etc (and from the comfort of their armchair).
Why do so many argue about such trivialities or dull geekery such as ABX testing, measurements about this hobby, do such ones spend more time discussing it than actually listening?
I'm a new guy so can someone please help me, why do the engineers go to such great lengths of listening to components over and over again and then chose the component that sound best? Surely they just need to copy someone else work, or just chose those that measure best?
I for one spend much more time enjoying listening to music than discussing it. In fact the only reason I'm even bothering to post on here right now is because it's something interesting to do to pass the time while it's quiet at work. :grin:
Everything that we can hear can be measured. But not everything that can be measured can be heard.
This means that scientific measurements are by far the most reliable and accurate method to use when designing HiFi electronics. As a general rule the better something measures in terms of lowering the distortion the better it will sound.
EDIT - Welcome to the forum BTW. 🙂
davedotco said:
Thompsonuxb said:
davedotco said:
Thompsonuxb said:
What the he,,,,,!!? Look at the post I've been involved with and what?
Lets take this post post for example a man is asking do more expensive amps make a difference, I say yes they do they will control your speakers in a way cheaper budget amps will not. Regardless if you like the sound they produce or not, thats personal to each individual - bottom line is you'll get what you pay for.
In the past I have openly challenged members to get together and have a simple comparisson test, yes it may not be practical but I know my points would be proven correct if we did come together this as nothing to do with magic ears but fact
Stereo is an illusion, its two boxes producing sound fed to them, yet they can produce a 3d image with tangible presence before you. I know its an illusion but I can enjoy it for what it is without needing to understand the science behind it I therefore will aknowledge differences in components, cables I have no problem with that.
alot thats written on the net is guff you want to believe knowing what you yourself can hear for yourself....good luck with that.
Just to close on this, there was a thread the other week were in an article some bloke claimed he could get two different amps to sound the same, remember it - it transpires in this article that he gutted one amp more or less replaced all its inards to achieve this task and it was accepted by the author as a success.....I mean it was considered a success, and accepted by some.
Look, Cheeseboy, this is a forum, its entertainment, its not life or death - like everyone else I just contribute to it, c'mon, theres no need for this hostility.
Point of order Thompson.
I assume you are referring to the Carver challenge, in which case you are wrong in fact.
The amplifier was not "gutted" in any way, in fact the design and the circuit was not changed at all. Some component values were changed so that the amplifier was 'voiced' to sound the same as the reference using a 'nulling' technique.
naaah the amp was gutted he even changed the PSU which prompted me to raise a thread how important is the PSU.....
Bottom line the amp was modified.quite alot too.
Sorry Thompson, the power supply was not touched, the effect was obtained by comparing the sound of the amplifiers (nulling). At no point was there any attempt to physically duplicate the amplifier, just match it's distortions, frequency response etc, etc.
As I said neither the circuit nor the primary components were changed, the amplifier was simply 'voiced' differently, in fact one of the Carver challenges (there were 2) produced an amplifier that sounded identical to an expensive Mark Levinson amplifier.
This amplifier was later put into production and marketed by Carver at about one tenth of the price of the Levinson.
O.K..... lol, when I have a moment maybe I'll look it up and this nulling technic thing too.....:grin:
I was speaking to my brother-in-law about this two evenings ago. He's a Royal Society professor and one of the world's leading experts on the brain physiology of sense perception.
He listed a number of areas in which he reckoned we're miles away from understanding how hearing works: frequency resolution, phase, complex harmonics, binaurality etc etc.
Alternatively you can look on wikipedia and give yourself the impression you understand how things work ...
Matt
No, no , no, no sense in producing anything that generates sound beyond 20khz cos it will be useless, didn't you know that? :grin:
Yup, but much of what is out there may not be 100% fact. Due to research, there's always something new we're finding out about the universe and its contents. If scientists knew absolutely everything about the human body, there'd be no disease or illness. Or at least, there'd be no incurable diseases.
Yep. You don't know what a scientific theory is.
And just because 'scientists don't know everything' doesn't mean you or I can fill in the gaps with any old nonsense and claim validity for it.
Yes in science theory works well enough to make things work - to turn on the lights, to make planes fly. But I personally haven't yet read anything conclusive on the limits of human hearing yet. In that regard I'm with David.
Anyone comparing a 200w amplifier to a 40w one, and then driving them both, for example, at 20w to compare them is being idiotic. You can take a Ferrari, and my old first gen Ford Focus 1.6 - reknowned for its ultra-sharp steering and handling and claim that both cars are equally good at 80km/h. Will both deal with a hairpin bend equally well at 120km/h? I doubt it.
I couldn't agree more. The most effective weapon is rational discussion. It's like expectation bias - it's used as a catch-all phrase whether or not it's relevant or not. Going back to the idea of visually equivalent "tricks" that usually only amuse, doesn't mean we have to question everything we see (such as a propeller appearing to rotate slowly backwards when viewed in a video). If we know our senses can be "fooled" we can then learn when & where to account for it (and when we can't). A simple example would be to undo an improvement to hear if it reverts or not as a simple reality check. We should all be sceptical - doubt can be a good thing.
So you have to driv ethe Ferrari at 180mph?
If I had a 200W amp. I would not play it at 200W I would probably play at around 1w to 10W!
Of course you are, skipping science classes presumeably.
I know that having any kind of scientific knowledge is deeply uncool but really......... :doh:
Missed this one.......lol.
eh, em.... yes it is stupid suppose the 20watt amp output/point of distortion is really low.
On my amp at home the Yamaha dsp-ax620 it responds differently at various levels between -50db and -40db the sound/imaging changes dramatically. At -50db its mellow fairly even in terms of 3d depth. At -45db the vocals jump clear of the speakers into the room, while left and right detail is thrown further out from the speakers, the sound stage grows and detail/seperation is more pronounced.
At -40db eyes closed you're lookng at a giant head in the middle of the room and eveything is bigger, seperated and clear.
Now if this 200watt amp you speak of is limited to its equivalent -50db so it matches the 20watt amp - you will never knowhow it'll drive the speakers in the system - but you would be able to convince someone they sound the same...... is that not stupid?
It's very simple once you realize that there are basically two camps:
OBJECTIVISTS - who work from specs and go deeply into measurements, as this explains what they hear. They put huge stock in testing (ABX / Double Blind etc) and proof. Their goal is getting a system that's as neutral as possible, which often takes them down the Active or Studio Monitor route. They have no time for what they call "foo", which incorporates things like fancy cables, conditioners and isolation devices. They have what I call, "A Science Brain".
SUBJECTIVISTS - They really don't give a stuff about neutrality or having an in depth knowledge of measurements. They go and listen, and then pick what sounds best to them. They see the appreciation of music as a subjective experience, where measurements do have a role, but aren't the most important factor. Quite often, they are open to the possibility that "foo" has its benefits. They try it, and are prepared to go with what they hear. They have what I call, "An Art Brain".
As you can see, they are the polar opposite of each other, and don't come within an Ass's roar of understanding each other. The Objectivists have little time or patience for the Subjectivists' "non scientific notions," and take every opportunity to tell them so, in no uncertain terms. The Subjectivists get very defensive in the face of such a confrontational approach, as they feel that what they hear is real. So the polemic arguments go on and on and on.............................. :wall:
As you can see, they are the polar opposite of each other, and don't come within an Ass's roar of understanding each other. The Objectivists have little time or patience for the Subjectivists' "non scientific notions," and take every opportunity to tell them so, in no uncertain terms. The Subjectivists get very defensive in the face of such a confrontational approach, as they feel that what they hear is real. So the polemic arguements go on and on and on.............................. :wall:
Sorry Cno but with the deepest of respect, that is complete bulls**t.
It is about as accurate as the contention that all passive speakers 'boom and tizz' and that all studio monitor types are 'harsh and forward'.
Sure there are some (people and speakers) that fit those stereotypes but really........ :?
Apologies again, no offence meant, I normally hold your posts in high regard.
If you want the most neutral, accurate system the only way to truly achieve this is through scientific measurement. That accuracy is only going to apply as far back as the recording process, but nevertheless it is the closest you are ever going to get to achieving accuracy with hi-fi equipment. In the strictest terms this is what 'Hi-Fi' or 'High Fidelity' actually is.
However, all the accuracy, neutrality and measurement in the world is absolutely no use if you don't end up enjoying the ensuing sound/music. The recording process is imperfect, ranging mostly from hugely flawed to not much more than OK, so you certainly aren't being accurate to the original performance or the music. There are many people who enjoy this accuracy and these listeners, the objectivists, are sitting closest to the real mening of 'Hi-Fi'.
There are also many people who prefer a more coloured sound and in different regards this can still be regarded as high quality if perhaps not, strictly speaking, 'high fidelity'. Ultimately if a more coloured system takes you, as an individual, into a closer relationship with the music, then it is every bit as successful as the objectivist's neutral and accurate system. We don't all feel the need to have any interest in measurements and prefer to rely on our ears, because although those ears are undeniably fallible and can be fooled, they are ultimately all we have for the pure enjoyment of sound and music.
Me? I'm a subjectivist, but I can perfectly appreciate where the objectivists are coming from. What I don't understand is the determination for one group to convert the other (in either direction). Enjoy what you enjoy, and let others enjoy what they enjoy. Neither approach is wrong and I don't believe they are even polar opposites. Ultimately both camps are exploring their different approaches to sharing and enjoying music.
Provided the levels of distortion (which is measurable) is suitably low in both amps then yes they will both sound the same.
I'm not saying that all amplifiers do sound the same though. That would be daft. Some amplifiers are deliberately 'voiced' to sound different by being warmer or brighter or whatever but this is really just a measurable type of distortion being added to the sound. Also many hifi amplifiers are underpowered and will start clipping at much lower volume levels than most people realise which can give them a distinctive sound (which some people seem to like).
But at the end of the day provided that the levels of distortion are low enough and the amplifiers are not being driven beyond their limits then yes both amplifiers will sound the same. While it's likely to cost more money to build a powerful amplifier there is no reason why a 200 watt amplifier can't have low distortion measurments like a 20 watt amplifier.
This is exactly how I feel.
I agree that it's the overiding need for one group to "educate" the other, that leads to the problems. The bottom line is, that if you don't enjoy the way your system sounds, you won't listen to it....which after all is the whole point.
Live and let live!
Personally I'm both a subjectivist and objectivist. Most of the time I enjoy listening to music on a hifi system the has the minimal amont of distortion possible which is why I tend to like brands like Quested, AVI and Genelec the best.
But depending on my mood and what music is being played I also sometimes like to listen to a smoother/warmer sounding system too. So now I have the most accurate system that I can afford which sound great most of the time and use a digital graphic equalizer to alter the sound whenever the music/mood takes me.
I see you as an Objectivist, but with potential. 😉
Live and let live!
I couldn't agree more Cno. Provided that you're listening to your music in a way that you enjoy who cares what equipment you use?
