Denon 700 AE or Marantz 6002
Heard the Marantz - simply superb amplifier for the price! Havn't heard the Denon, but if it is up to their usual standards it will be a bit dull in comparison. Marantz, I should think, is WAY better.
I was talking about cd players not amps... but thanks anyway!
[quote user="bojanisimo"]I was talking about cd players not amps... but thanks anyway!
[/quote]
Substitute the usage of amplifier with cd player...just as good as the amp!
I have the Denon you are all talking about but I doubt that you have tried it. I will be honest and say that I have not tried the 6002. However, I have tried the Pioneer PD-D6-J (I owned it for a short while) which is more expensive than both and was very close to beating the Marantz (it's price probably went against it) in the Super Test. I have also demo'd the Rotel 06 with my RS6s. All I can say is that the Denon was as good as the Pioneer, and better built. I would honestly say forget what you have read and try both - Richer Sounds sell both - as do Sevenoaks. I reckon you will go the Denon way.
[quote user="Gerrardasnails"]I have the Denon you are all talking about but I doubt that you have tried it. I will be honest and say that I have not tried the 6002. However, I have tried the Pioneer PD-D6-J (I owned it for a short while) which is more expensive than both and was very close to beating the Marantz (it's price probably went against it) in the Super Test. I have also demo'd the Rotel 06 with my RS6s. All I can say is that the Denon was as good as the Pioneer, and better built. I would honestly say forget what you have read and try both - Richer Sounds sell both - as do Sevenoaks. I reckon you will go the Denon way.[/quote]
Excuse me, you doubt that I have tried it? I wouldn't have commented if I hadn't. I work in a hifi shop.
I've also considered the Pioneer as well. It is fair to say that I'm not quite the Marantz fan 'cause I don't like harsh ending sound (IMHO) which someone might prefer.
Thank you for your answer!
[quote user="Wild Willy"]The Marantz is a better all 'round player to these ears.[/quote]
The Marantz strenght, IMHO, is his musicality, his midrange and openness, but I still don't like his heights.
