Hi' i was really hoping you included the Wilson Benesch square two's in your group test.
They were your fav speakers for the past two years and you considered them to be better or equal against the ATC 40's.
I,m just curious what the results would had been if you had them to compare against the Spendor A6 and ATC 40's.
Do you consider them better or you still know the Spendor's is your first choice.
Thanks.
Thanks.
