Lo Fi[b said:]I have seen this wiring idea on the Chord Company website[/b]. Positive to treble and negative to bass and of course jumpers but have not tried it yet myself, but will when I get new cables.
crang said:HI
No your not the only one! Been on this forum nearly 5 years I am astonished that this has not come up before .
I have had my BX2s bi-wired and single wired with links made up of Maplins OFC cable with + to bottom red - to bottom black, tried + to treble - to bass YES there is a real difference even detected by my philistine OH!
The main differences are 1 tighter bass . 2 better seperation with instruments more clearly defined in their own "space".
wierd!
Benedict_Arnold said:What has been talked about above is instead of bi-wiring, not in addition to it.
If you only have one set of speaker terminals on your amp, or "Zone A" and "Zone B" terminals fed by the same power amp or amplifiers inside the box, you won't get much benefit from bi-wiring, as I think most will agree. The main benefit from bi-wiring comes when you have two power amps. If these are both stereo-only, you use on to drive the trebles, the other to drive the bass. Some designs can be run in twin mono mode, with one box used to drive each speaker.
Therefore I would not advise cutting your cables in half, just for the experiment. In fact I would NEVER advise anyone to cut up expensive cables.
Vizzage said:Ok. So i've been a-tryin' this thing about putting red to treble, black to bass. Obviously I can't tell the differenc bcoz I'm a philistine. But it's occured to me that my speaker cable is more than twice the length it needs to be. I've hesitated to shorten it bcoz it's so valuable. But should I in fact chop it in half and bi-wire my speakers? Does bi-wiring mean you shove both wired into the output on the amp, have both cables running to the speaker, and plug one into the treble red & black, and the other cable goes into the bass red & black? Is it much better?
BigColz said:Benedict_Arnold said:What has been talked about above is instead of bi-wiring, not in addition to it.
+1 for don't bother bi wiring or cut expensive cables
using two amps, one for treble and one bass is bi-amping and can bring benefits as its twice the power
andyjm said:BigColz said:Benedict_Arnold said:What has been talked about above is instead of bi-wiring, not in addition to it.
isnt the point of having expensive speaker cable to improve sound quality? Why compromise that by having cables twice the length required?
andyjm said:Strangely, of all the posts on this thread, this post makes the most sense.
Vizzage said:andyjm said:Strangely, of all the posts on this thread, this post makes the most sense.
Sir, I thank you 🙂
Benedict_Arnold said:andyjm said:BigColz said:Benedict_Arnold said:What has been talked about above is instead of bi-wiring, not in addition to it.
A metre or two either way won't change your speaker cable performance one jot. Wikipedia gives some good rules of thumb for maximum speaker lengths based on wire gauge:
http://en.wikipedia.org/wiki/Speaker_wire
BTW - the higher the number the smaller the wire - it comes from the number of times the wire would have to be drawn down through a die to achieve a given diameter, so think of 16-gauge wire as requiring 16 draws, 22 as requiring 22 draws or steps.
So unless you live in Blenheim Palace I wouldn't worry 🙂
What happens if you keep cutting speaker wires down in length is you end up with a huge collection of jumper cables for bi-wire speakers....
Benedict_Arnold said:What happens if you keep cutting speaker wires down in length is you end up with a huge collection of jumper cables for bi-wire speakers....
andyjm said:]
On one hand there are a group of posters who believe introducing 2 inches of thick conductive jumper plate into a speaker circuit is clearly audible, and there are others who think introducing a metre here or there of speaker cable makes no difference. Can't be both now, can it.
Vizzage said:andyjm said:]
yes, if there's an inverse relationship between length and making a difference ("less is more" ;-)
Otherwise, good point.
