labelman68
27
What's a great HiFi streaming setup that doesn't take up too much room. I'm really trying to go with just a few boxes, rather than stringing together a bunch of stuff. I don't need volume- it's a small room- but want quality sound both in my phones and speakers (ideally bookshelf). I do have a Sennheiser HDVD 800 and matching headphones + Martin Logan 4's. Can I just stream FLAC files via my macbook pro and get the high resolution sound?
Infiniteloop
51
6
Have a look at the Chord Hugo TT2. Great DAC and Heaphone Amp. It will even power a pair of speakers!
Plug your Macbook Pro directly into the TT2, add speakers and off you go!
I'd have a look at Audirvana + software and link it to your iTunes library too.
Deleted member 188533
Nope. You're using the DAC in the Sennheiser HDVD 800. All the laptop is doing is sending it 1s and 0s.
Reactions: Friesiansam
