Can one set of speakers be used on two different amplifiers one being an av amp the other a stereo amp as long as the speakers are bi wire capable. Or do I need two do somenthing else.
You need a speaker switch between the speakers and the amps: if you connect both amps to the speakers using the biwire terminals you risk damaging the speakers and/or one or both amps.
Thankyou for your replies it sounds as if the beresford will work as I am looking at buying some kef speakers to use as surrounds but I also want to use them on my marantz 6004 set up,
