Vladimir said:As long as you don't join a hi-fi forum to read iMark throwing poo at Neil Young, you are fine. Rule #1 is epic stuff.
*biggrin* that brings up some very vivid imagery in my head 🙂
Vladimir said:The sad part is if you read Rule #1, you already broke it. Therefore, it should be printed in every hi-fi magazine, hi-fi showroom entrance door, every flyer and brochure.
Vladimir said:Prevention is everything.
andyjm said:Reijer,
This is very helpful. I am afraid you are going down the same path we all have when trying to measure something, it is actually quite difficult to get decent results. Welcome to the real world.
Looking at your plots, something is seriously adrift as they are all over the place. My guess is that something is clipping in your monitoring chain or you have a signal grounding problem.
I would suggest you start from scratch.
Connect your analyser to the first step in your chain (PC soundcard?) and generate a 0dBFS 1 KHz sine wave (WAV file from the web). Most analyser software has a 'scope function, so display the trace and check that nothing is clipping (you should have a beautiful sine wave with nice rounded tops) . Now run a spectrum, you should have a single 1KHz spike, way above a load of noise hash. Depending on how good your setup is, the noise should be at least 60dB below the peak.
Now run a 20Hz to 20KHz sweep (average 10 sweeps), you should get a pretty flat response, no dips or bumps.
If this is OK then move through the chain, one step at a time following the above tests at each stage. If the signal is clipping, or there is too much noise, or if you don't get a flat sweep, then you need to find the problem and fix it before you move on.
When you finally get to the speaker terminals, expect more deviation, but the sweeps and noise gap should still be reasonable. Once you move to the speaker / mic combination, then all bets are off. Just remember that unless you are in the middle of a field or an anechoic chamber, then you are measuring the room as much as the speaker.
Good luck.
Reijer said:One thing is for sure: Cables can do differ, even in the cheap region of the speakercableomniuniverse.
Back to everyday things..... *music2*
davidvann said:what i dont understand is if cables dosent make a diffrence why is it i cant see people's signature speaker cable' bell wire'
davidvann said:why on one hand some people post cables dont make a diffrence tell us not to buy hifi bling cos its a waste of money
Freddy58 said:Is it the end yet?
CnoEvil said:Freddy58 said:Is it the end yet?
BIGBERNARDBRESSLAW said:I only have one problem with this, and that's that the money could actually be used for something good, rather than something wasteful, vain, and utterly pointless.
BIGBERNARDBRESSLAW said:Freddy58 said:Is it the end yet?
No, I've just dropped a wasp nest in to stir things up a little. *biggrin*
