I have just changed Broadband supplier, from BT to Orange, and the router they have sent is a Netgear DGN1000, to replace the BT Homehub2.
Since changing provider I have had some problems, mainly the Wi-fi signal dropping out, even if used in the same room as the router.
My question is this, is the router at fault or the Broadband service, in your opinion ?
Would a better router be the answer and if so which would you recommend ?
Also my signal upstairs is patchy, so would "homeplugs" or something else be the answer, again any recommendations/opinions would be gratfully recieved.
Cheers Richard.....d'oh!(you know who you are...lol).
