Dear all members,
After spending hours watching lots of reviews I plan to totally transform my setup... but I face quite differents ways to do it.
Which option would you pick from those below ? It goes from the all-in-one, to the all seperate...
A- Buchardt A500 (active speakers with wireless connection !) difficult to do a more "all-in-one" setup ! (~3500€)
B- Heaven 11 Billie to get tube preamp + class D amp + digital streamer & DAC all-in-one integrated (~1000€)
C- Tube amp Willsenton R8 (~1200€) + Digital streamer : AudioLab 6000N (~500€) or Cambridge CXN V2 (~900€) or Bluesound node 2i (~500€)... still don't know which one would be the best option + no DAC because already within the streamers.
D- Digital streamer + no DAC + Schiit Freya tube preamp (~900€) + XTZ Edge A2-300 class D amplifier (~500€)
+ in Option: DAC Denafrips ARES II (~700€)
For information, today I simply use a Yamaha RN-803D all-in-one streamer+DAC+amp (~700€) , linked to Dynaudio Emit M20 speakers (~700€) that I will not change so far + a RegaPlanar turntable. The sound is much better than before, when I used a small hifi station but still not a "whaooo" effect...
Is one of those configuration a sound quality for budget the best ? Or does it all depends of my ears preferences ? Or should I go for something else ? Or should I do nothing because it will not change much the result ?
Sometimes I feel integrated systems will be more solid because build all together, easier to plug & play, space saving..., and sometimes I feel that getting the best for each component will be better for both the sound experience and the upgrade capabilities...
Thank you so much for your help, insights & advices.
Mathieu.
Mathieu.
